05-04-2013, 06:01 PM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: NW San Antonio
| Rear Axle Questions
Hey everyone, I'm having a difficult time trouble-shooting a binding issue on a rear axle I'm putting together. First, the parts list:
Since first assembling the axle and pulling it back apart, I have shaved the inside of the axle tube so the lockouts slide on. It is still a bit tight, but not much tighter than the aluminum chubs when I assembled the front axle. In addition, I removed the paper gasket that goes between the ring gear and locker. Still, the mesh is too tight for my liking. Suggestions? Thanks in advance, Jon D. |
05-04-2013, 08:47 PM | #2 |
Rock Stacker Join Date: Apr 2013 Location: usa
| Re: Rear Axle Questions
Are your lockouts on straight? I would imagine that would cause some binding.
05-04-2013, 08:52 PM | #3 |
Not sure. The play is fine until I slide the lockouts on. Maybe I'll try it w/o the beef tubes...
05-04-2013, 11:10 PM | #4 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
If you don't seat the inside pinion shaft bearing fully, it pushes the pinion into the ring gear, causing binding.
05-05-2013, 06:03 AM | #5 |
Does the 43/13 use a different size bearing on the gear side of the pinion?
05-05-2013, 06:38 AM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Rear Axle Questions |
05-05-2013, 11:58 AM | #7 |
I dremeled a bit more where the beef tubes seat on the end of the axle tubes. It is a little tight still, but no where near what it was. We'll see how it holds up.
Rear Axle Questions - Similar Threads | ||||
Rear Axle Questions | whiteman | Axial XR10 | 13 | 09-10-2010 07:06 PM |
Rear steer lockout so you can still mount stuff on rear axle | bill400ex | Duratrax Cliff Climber | 9 | 02-16-2010 07:49 PM |
