05-05-2013, 09:36 AM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| gearing for a scx 10 with a rc4wd 2 speed
just putting the finishing touches on this truck. Has 2.2 tsls and 55 turn motor. needs some pinions for it. The stock pinion was a 20 tooth. Maybe a 15 tooth would be good? Only thing I know for sure is I need a 32 pitch gear... Thanks for the help |
05-05-2013, 09:50 AM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: gearing for a scx 10 with a rc4wd 2 speed
Start with the one the tranny comes with and go from there. Also would help to know if you are using 2s or 3s.
05-05-2013, 10:21 AM | #3 |
im piecing it together. didnt come with one.. will be on 3s
05-05-2013, 12:02 PM | #4 |
anyone? come with a 8 tooth ?
05-05-2013, 07:12 PM | #5 |
Newbie Join Date: Mar 2012 Location: Brunswick, Maine
It comes with a 15/60 pinion spur combo. I run mine on a 2800kv brushless and found it just a tad fast so i'm going to a 12/60 with a 55 turn you might want to look at 20/60 if you want and wheel speed, but thats just how I like it, good luck.
05-05-2013, 07:41 PM | #6 |
found a 11 tooth might fit.. will see
01-02-2014, 03:38 PM | #7 |
Newbie Join Date: Sep 2005 Location: Costa Rica
Maybe some one could shed some light please..have been reading gearing and stuff but it kinda got confusing.. have a wroncho with the ax2 speed with stock gearing 15/60, 35t holmes torque master and 3600mah nimh battery. have just been playing inside and took it out first time yesterday and after areound 10 min I started smelling smoke and then saw it so i unplugged the battery. Motor was suuuper hot. Was driving it slow in 2nd gear for a while... have a 12 tooth at home should i give it a try? Also have a tekin 35t which should be faster right? thanks for your help guys... |
01-02-2014, 10:35 PM | #8 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
I run 3s, 35t, and 24/84 48 pitch gearing. first gear is slow enough that it creeps pretty slow and second gear has plenty of wheel speed. I have two trucks set up like that and love it. I do everything from flat trail running to hard core rock crawling. Works great for me. |
gearing for a scx 10 with a rc4wd 2 speed - Similar Threads | ||||
Gearing for speed | kjardine | Newbie General | 2 | 07-24-2012 11:19 PM |
Gearing for speed | kjardine | Axial SCX-10 | 3 | 07-22-2012 01:10 PM |
Gearing for speed question | PowerCrazy | Electronics | 9 | 04-27-2011 09:28 AM |
Speed and Gearing chart? | acrosteve | Electronics | 3 | 08-07-2009 05:03 PM |
Low gearing Vs. speed? | nktrnl | General Crawlers | 12 | 08-06-2004 08:41 PM |
