Thread: Savox SW-0231MG servo install
Old 12-26-2013, 09:25 AM   #1
Default Savox SW-0231MG servo install
Hello, I'm new to hobby RCs and building my first kit, the Axial SCX10 Jeep Rubicon. I am attempting to use mostly waterproof electronics and wound up buying the Savox SW-0231MG servo. Some sites describe it as a "tall" servo, and the dimensions do seem larger than most. The result during my install is the upper steering link is too far forward, at an angle, and not parallel to the lower link (as shown in the picture). The servo still seems to rotate from lock to lock, but the "interface" between the horn and the upper link seems a little off- for lack of a better phrase. I can't fully tighten the nylon nut onto the screw, as it requires a little play at full turn, due to the angled link.
Is this something I should be concerned about? If so, any thoughts on how to correct it? I have limited capabilities for fabrication, but could try. Any feedback is much appreciated. Thank you.
jsome is offline   Reply With Quote
Old 12-26-2013, 10:56 AM   #2
Default Re: Savox SW-0231MG servo install
looks ok to me if its not binding anywere just leave it alone
boohoo is offline   Reply With Quote
Old 12-26-2013, 11:13 AM   #3
I had the same issue with my G6 build..I ended up using the Losi Servo horn it pushes the servo arm back into proportion the the lower link. You can see the difference in the pictures below
or you can just shave off some of the plastic that the servo mounts to (the ones that attach to the servo plate)
pvo_srt4 is offline   Reply With Quote
Old 12-26-2013, 12:52 PM   #4
Great, thank you both for the info. I think I will go with boohoo's suggestion to leave it be for now, while ordering the servo horn that pvo_srt4 recommends.
pvo_srt4, is the part you speak of Losi LOSA99039? Thanks again.
Old 12-28-2013, 10:07 PM   #5
yes that is the one, when i get my rig back i'll take some pics.
Tags
savox, scx10, steering linkage, sw-0231mg
Savox SW-0231MG servo install - Similar Threads
Savox servo Bogncrawl Electronics 8 02-17-2013 08:25 PM
Savox servo ryno mike Electronics 2 05-17-2012 08:31 PM
Savox servo?? mnypit71 Electronics 4 01-10-2011 10:23 PM
Servo Crown(TM) Servo Armor(TM) install PinchFlat Chassis and Suspension 8 06-06-2008 11:08 AM
