08-11-2013, 10:02 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
| FXR Esc, recommended drag brake for JK kit?
I have my kit built and all my electronics, including my FXR and Tekin 35T. I have only very limited experience with drag brake, mostly just the 'smart brake' system on the Twin Hammers. I know the FXR has like 11 settings for drag brake, but I wondered if people with more experience might have a recommendation as to what setting to use. My rig is mostly stock, and i need to move the battery tray over the front. I will be using, most likely, Zippy 2200 Compact 3s batteries, so they won't be that heavy. And I'd like it to creep just slightly up or down. I plan to play with it and figure it all out, but a jumping off point is all I really wish to find. Thanks |
08-11-2013, 10:08 PM | #2 |
| Re: FXR Esc, recommended drag brake for JK kit?
Three.
08-11-2013, 10:08 PM | #3 |
| Re: FXR Esc, recommended drag brake for JK kit? |
08-11-2013, 10:12 PM | #4 |
| Re: FXR Esc, recommended drag brake for JK kit? Nah really, it depends if you want a slow roll, or more of a lock up. Just play with it. |
08-11-2013, 10:18 PM | #5 |
| Re: FXR Esc, recommended drag brake for JK kit? Well I will start with a three and see what I can do from there. I would more like it to roll very slowly than to lock up completely, but then again some of the hills on the land we have are pretty steep, so maybe a solid stop would be better. Either way, heh.
08-11-2013, 10:25 PM | #6 |
I like lots of drag brake but it definitely tests how smooth you are with the throttle. Once you figure out how to roll off the throttle a lot of drag brake works great. If you can't get smooth with the throttle release than you will endo every time you bump over a gap. I say try it with lots of drag brake and practice getting smooth.
08-12-2013, 10:09 AM | #7 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
FXR Esc, recommended drag brake for JK kit? - Similar Threads | ||||
FXR Setting Drag Brake Crawler | ZSKYLAR | Electronics | 2 | 06-09-2013 12:46 PM |
2X FXR drag brake question | salty | Axial XR10 | 4 | 06-20-2011 02:06 PM |
Drag brake Tekin FXR | Force5 | Electronics | 8 | 02-15-2011 10:42 AM |
DX3R and FXR Drag Brake Issues... Help Needed. | Nachies | Electronics | 16 | 04-15-2009 09:51 AM |
Tekin FXR drag brake loss | fullsyzz | Electronics | 3 | 04-06-2009 11:21 AM |
