08-26-2013, 06:14 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Australia
| Jeep Rubicon JK Diffs
Hi all, I apologize if it's been asked before but I bought an Axial Jeep Rubicon and I don't use it for rock crawling. I have a trailer I pull and it spends most of its life on sealed ground. What I was wondering is will this damage the diffs as they are locked? I've heard that Wheely King open diffs fit the Axial diffs. Would it be worth swapping them? Thanks Mat From the Brain of Mat |
08-26-2013, 06:58 PM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Esko
I'd keep them locked. Shouldn't hurt them. I've heard of people ruining diffs on carpet, but outside ground I think will be fine. Probably just not blacktop.
08-26-2013, 07:03 PM | #3 |
| Re: Jeep Rubicon JK Diffs
The lockers will see WAY more abuse bound up in the rocks that they will cruising around on flat ground. If you want to unlock them you can use gears from an ax10, exo, or wheely king.
08-26-2013, 08:10 PM | #4 |
Thank you both. From the Brain of Mat |
08-26-2013, 09:20 PM | #5 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
You all say "locked diff" like there is one and you can unlock it. Really SCX10 locked differential = no diff.
08-26-2013, 09:24 PM | #6 |
| Re: Jeep Rubicon JK Diffs There is a differential carrier with a locker in it. Pull out the locker and stick in some ax10 diff gears and the differential carrier is unlocked. It's not like it has a spool.
08-26-2013, 09:34 PM | #7 |
It sounds like put actual differential and it is there)) For me in SCX10 is half axles adaptor. But it does not cancel the fact you can replace it with diff gears. |
08-26-2013, 09:56 PM | #8 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I would at least unlock the front so it doesn't crow hop really bad. Not that hard to do.
08-26-2013, 09:57 PM | #9 |
Quarry Creeper Join Date: Jul 2011 Location: charlotte
put the spider gears in the front and leave the rear locked...
08-26-2013, 10:22 PM | #10 |
Thank you all. I'm ordering some ax10 gears and shafts now. From the Brain of Mat |
Jeep Rubicon JK Diffs - Similar Threads | ||||
Jeep Rubicon vs. Jeep Cherokee | DAGUL | Scale Videos! | 1 | 03-22-2012 05:26 AM |
Jeep Rubicon CR-01 | cman_1500w | Tamiya CR-01 | 15 | 03-14-2011 05:33 PM |
Jeep Rubicon | venom813 | 1.9 Scale Rigs | 15 | 03-21-2009 09:17 PM |
Jeep rubicon 80% done | trost | 1.9 Scale Rigs | 23 | 02-03-2009 03:09 PM |
1:1 jeep at rubicon | jeepguy | 1:1 Full Size Vehicles | 19 | 04-05-2006 11:20 AM |
