09-30-2013, 09:57 AM | #21 |
Rock Stacker Join Date: Aug 2013 Location: St. Louis
| Re: foff dingo build rec's
I replaced the servo..again grrr! I was going to get a Traxxas 2075 but got talked into Savox's new offering sw-1210sg with 277 oz. torque. The failed Savox it is replacing had a bearing shred which shifted the gear post and allowed teeth carnage. Warranty time. I have it running 5000mah 3s lipo and it is running about as fast as the truck is realistically capable. Lots of screw checking and loctite. Quite happy with the hobbywing combo, wp 125 amp esc and 4600kv 4 pole. 1.9 ripsaws gettin another try, still stuck in tire limbo. Jeep body almost complete. I extended the front wishbone 3 mm to clock the axle a bit and improve the shaft angle. THis required me to mod a chasis brace and lay it on its side to clear the servo horn. Worked very well actually, it is the one zip tied to the bumper posts. With the rear already wraith lenth extended and clocked I was able to take the internal limiters out of the shocks without causing a bind. I needed the full travel for wear and tear on landings. I used two sets of bent wraith links in the rear. There is just enough clearance for the upper and the combo allows for mega clearance in the rear of the truck. |
10-01-2013, 08:53 AM | #22 |
| Re: foff dingo build rec's (short run vid added)
Just quick test runs checking the shaft durability after the axial blog mod. Lots of throttle left, pinion going smaller. [IMG][/IMG] |
10-06-2013, 08:18 PM | #23 |
Trying to get the 2 speed happy...grrr |
10-12-2013, 09:22 AM | #24 |
It's getting there. The two speed and custom wraith length links are done. I have a micro waterproof servo for the 2 speed to swap for the one on there now. I had to change body choice to the Proline 4 door JK due to the added length. Finally drive shafts, I bought some integy ax10 at the lhs recommendation. Well made but the damn coupler cups do not fit the outputs of the scx10. Drilling them out is not going to be easy. I will try to get some vid of the 2 speed in action. It makes it more fun to drive. |
10-20-2013, 03:41 AM | #25 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
I've had good sucess with cheap solar servos. Particularly the D772. Its a brute, slow but ridiculously powerful!
10-20-2013, 09:10 PM | #26 |
| Re: foff dingo build rec's |
10-20-2013, 09:33 PM | #27 | |
| Re: foff dingo build rec's Quote:
I bought two 772"s... sorta loud... prolly due to the alloy casing... At 7.5v it will put out it's max power/torque... but I'm fine with running at 6.0v... runs somewhat cooler. * use a BEC for this servo. don't think they're water tight either so might want to follow up on that. for a "low cost" HT MG Servo... there is no equal. And IMO it ranks up there with some of the more pricey servos. The 772 isn't lighting fast... but it does well for a crawler... when crawling or at slower speeds. Last edited by TacoCrawler; 10-20-2013 at 09:44 PM. | |
10-20-2013, 09:45 PM | #28 |
watertight rules on this rig but not the other thx taco
foff dingo build rec's - Similar Threads | ||||
where the Foff am I gonna foff build | ctrwannabe | Formula Offroad | 8 | 11-30-2012 07:37 PM |
First FOFF build | banditrc | Formula Offroad | 10 | 05-02-2012 09:12 PM |
I want to build a FOFF ( Ax-10 ) | West Cork Basher | Formula Offroad | 4 | 10-14-2011 03:09 PM |
Going to build foff need help | Motomeyhem | Formula Offroad | 2 | 08-03-2011 12:39 AM |
