10-30-2013, 08:01 PM | #1 |
Newbie Join Date: Oct 2013 Location: Chicago
| New home made links
Just thought id share.revo ends with 8/32 all thread and ss brake line sanded then painted candy apple red.total cost was about $25 with paint |
10-30-2013, 08:17 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: New home made links
Looks good..ill be changing from my aluminum tubes to s/s tubes in the near future.
10-30-2013, 08:23 PM | #3 |
Pebble Pounder Join Date: Sep 2013 Location: Jacksonville
I use 1/4" black poly tubing, Slides like Delrin! Fits right over the 8-32 rod snug. |
10-30-2013, 10:43 PM | #5 | |
Quarry Creeper Join Date: Feb 2010 Location: Woodland Park, CO
| Re: New home made links Quote:
Thanks for the idea, Joe - I need to get some more tubing from ya... Troy ScalerFab | |
10-31-2013, 08:22 PM | #6 |
Newbie Join Date: Oct 2013 Location: in the sticks
how did you get the rod ends to fit?
10-31-2013, 10:12 PM | #7 |
m4 is pretty close to 8-32. Running an 8-32 tap up into the rod end helps to start it too.
10-31-2013, 10:42 PM | #8 |
Pebble Pounder Join Date: Sep 2011 Location: Between the thoughts of yesterday and the ideas of tomorrow
What length did you cut for each. I've been wanting to make some and from what searching I've come across is looks like 125mm for the uppers and 130mm for the lowers. Does that sound about right?
11-01-2013, 03:07 PM | #9 |
Yea u ran a 8/32 tap on each end and make it easy to thread on
11-01-2013, 04:25 PM | #10 |
| Re: New home made links I'll have to check when I get back to work Monday I made a jig I set the ends on to give me the sale length as stock
11-01-2013, 08:02 PM | #11 |
Pebble Pounder Join Date: Oct 2013 Location: Stockton
Is it just easier to use all thread than to thread a piece of rod.What's the scoop
11-01-2013, 09:12 PM | #12 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
Yeah most people just dont have a way to make threads so its just easier. Then you just put some type of sleeve over it for added strength and so the threads dont hang up on everything Sent from my iPhone using Tapatalk - now Free |
11-01-2013, 11:06 PM | #13 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
Check out mcmaster-carr. I mocked up and got an estimate on links. Ordered Solid 1/4 aluminum standoffs that are threaded 3/4 in on both ends for 8-32. Picked up their 8-32 3/4 studs and I just cut off 1/4 and added revo ends and have a nice set of links that cost $40 roughly. Sent from tinker room pro |
11-01-2013, 11:46 PM | #14 |
In all honesty aluminum links that are threaded are stronger than sleeved tubes( much thicker tubes)..I made a set with 8-32 all thread and thin wall aluminum 1/4 tubing and the tubes dent and bend very easily. Was thinking about switching to 3/16 steel brake line as it should be much stronger. Delrin tubing is best for allowing the links to slide over rocks I hear. |
11-01-2013, 11:57 PM | #15 | |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
While its a bit more work, this way looks much more scale, are easier to make multiple bends in, and last a long time. If you use ss, rust isnt an issue either. | |
11-02-2013, 12:00 AM | #16 |
RCC Addict Join Date: Aug 2007 Location: Burbank
If you get the right rod from SK it already has a hole, all you do is tap it to 8/32 and your done!
New home made links - Similar Threads | ||||
Home Made links | Leadfoot_11 | General Crawlers | 2 | 11-13-2012 07:47 PM |
My Home made links. | ouchman | Axial SCX-10 | 5 | 11-06-2012 05:54 PM |
Home made lower links ? | heavy chevy | Team Losi Comp Crawler | 11 | 06-16-2012 07:28 PM |
home made links | Losi man | Losi Mini-Rock Crawler | 5 | 08-21-2009 12:20 AM |
