11-01-2013, 02:30 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: scotland
| modded steering mod does it work
was wondering if anyone has modded there steering drag link to run two short ones of the servo arm and doing away with the long bottom one its just that my mate has done this and he say`s it gives you way more steering i havent seen it yet before someone ask`s but i did see a pic on google but cant find it again
11-01-2013, 03:14 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: modded steering mod does it work
You only have so much steering lock to lock as it is unless you have a few more mods included that will allow more steering....Ive thought of trying what you described but I don't see how you would get more steering from it...If anything it may make the servo work under less stress..Or perhaps relieve some of the stress of only one link connected to the one side.
11-01-2013, 03:28 PM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: Fort Worth
Honestly my tires get into my shocks long before I run out of steering limits.
11-01-2013, 04:47 PM | #5 | |||
| Re: modded steering mod does it work Quote:
Quote: | |||
11-01-2013, 04:54 PM | #6 | |
| Re: modded steering mod does it work Quote: Think of a rack and pinion steering set up where you have a rod on each side moving instead of one short arm moving a longer one.,,Inherently you lose a little suspension on the side your single arm is on the scx10 as the frame hits the top link.. so you will just lose the same amount on the other side...Not sure how it would work but it crossed my mind before,.,, Would just need a T shape servo arm...One you can attach to the regular arm then two links on the ends of the T. | |
11-01-2013, 04:57 PM | #7 |
@ BooHoo I use 1.9 tires and at full steering with universal axles im not hitting my shocks but I can see if you run big wide 2.2 tires ;provided it would increase steering then it may be a problem Don't attempt that much more steering without universal axles as you will likely create a binding issue with your axle and break them or something else. Last edited by 6sharky9; 11-01-2013 at 05:21 PM. |
11-01-2013, 05:23 PM | #8 | |
11-01-2013, 05:50 PM | #9 |
RCC Addict Join Date: Oct 2012 Location: Norcal
While this is not a SCX10, you talking about this setup?
11-02-2013, 02:25 AM | #10 |
| Re: modded steering mod does it work |
11-02-2013, 03:13 AM | #11 |
I was picturing two upper links while still having a long lower link.... Another upper link going to the other knuckle and using a T shaped servo horn. A triangle design. Last edited by 6sharky9; 11-02-2013 at 03:35 AM. |
11-10-2013, 03:40 PM | #12 |
i finally saw what my mate done and its the same thing thats on the wraith further up in this thread and it does seem to make a difference to how he can crawl now. the angles he can get to say go around a sharp corner amazed me i didnt think it would be so good
11-10-2013, 08:38 PM | #13 |
Rock Crawler Join Date: Apr 2012 Location: Sparks
basicaly your looking at suicide steering! i ran it for a long time on my wraith and was wondering why i was roasting servos constantly went back to traditional style V.P. titanium steering links and booyah no more problems!. IMO its only good on a light truck (up to about 8 pounds).thats my 2 cents hope it helps!!
11-10-2013, 08:59 PM | #14 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Yes, as stated above, that's called suicide steering. It's been tried by many on here with not a lot of success.
modded steering mod does it work - Similar Threads | ||||
***REVIEW*** DLUX Fab 70* XR10 modded steering shafts | chicklet | Axial XR10 | 6 | 07-10-2013 01:18 PM |
new steering on the new PRO/ OTA steering mod axialjeepster | AxialJeepster | Losi Mini-Rock Crawler | 4 | 10-14-2012 01:03 AM |
Xirtic + JP High Clearance Steering Mod on Mod | JeffK11 | RC4WD Bully | 1 | 02-01-2012 09:55 AM |
modded servo mod on a xmod... | Stallion1967 | General Crawlers | 0 | 08-24-2007 11:17 AM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
