12-04-2013, 12:15 PM | #1 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
| PVO_SRT4's G6 Post Build
Everyone has seen the pre build so Im going onto the next step So far im waiting on my Tires, Rims, Motor and ESC to arrive, ive mounted my 2.2's for now..I hate painting it sucks The kit went together really easy and here is the fleet of scx10's |
12-18-2013, 07:25 AM | #2 |
| Re: PVO_SRT4's G6 Post Build
new rims came in RC4WD 1.9 6 lugs Hitec 5646 servo, this is my 1st ever Hitec servo ive only ran Savox's in the past did the upper rod end links now all i need is my esc and motor to arrive |
02-06-2014, 01:00 PM | #3 |
got my truck back finally with new ESC and BEC everything has been waterproofed, BEC has heat shrink over it and silicone on each end to prevent water from getting in ESC plasti dipped |
07-06-2014, 05:24 PM | #4 |
thought i would give a little update on this rig.... this rig is freaking flawless, seriously when people ask what to upgrade honestly NOTHING is needed this this works well i do have hitec servo, BEC, aluminum rear lockouts, C-hubs and knuckles and RC4WD 1.9 beadlock wheels, and aluminum upper links....stock gears, stock drive-shaft |
07-20-2014, 06:51 AM | #5 |
decided to upgrade the bevel gear set F/R 43/13 this is what the housings looked like when i took them apart, time for marine grease and new bearings rear front |
07-23-2014, 11:12 AM | #6 |
another quick update: axial's web site states the lower gear range set reduces torque twist (43/13)....i find that with the 20T motor its still there so i will be dropping the motor for a 55T axial motor this weekend is a local comp cant wait to lay the smack down on those $1000 rigs |
07-23-2014, 07:08 PM | #7 | |
| Re: PVO_SRT4's G6 Post Build I love the steel beadlocks six lug...RC4WD and Hot Racing, they are great wheels that are often overlooked for more bling. v Quote:
Do it to it and good luck! | |
07-24-2014, 01:44 PM | #8 | |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: PVO_SRT4's G6 Post Build Quote:
07-24-2014, 04:11 PM | #9 |
^^ 55T too slow?
07-24-2014, 04:39 PM | #10 |
| Re: PVO_SRT4's G6 Post Build |
07-24-2014, 06:11 PM | #11 |
| Re: PVO_SRT4's G6 Post Build 35 or 45 turn on 3s and gear it. I like 45 allows me to run little bigger pinion, especially useful since I run 32 pitch gears. 55 should be ok if you gear it up, I run 45T 13/56 32 pitch 3s lipo. |
07-24-2014, 07:09 PM | #12 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Well since no mention of what battery is being used ,I guess ill speculate a bit. if youre going to use a 2s battery then run a 27T motor with the stock spur and a 16T pinion if you want a 50/50 mix of speed for the hills and control for the obstacles. Considering you've underdriven the rear, you will get even better control at slow speeds over obstacles but still maintain a great wheel speed up front to help up those hills. 3s.. definitely a 35T...this gives you what you would get with a 2s and a 27T..just gear higher than 16T a 2s on a 35T or higher will take your chances of success away on some obstacles you may encounter...don't do it. 4s..I would still stick with a 35T but gear even higher than with a 35T just my .02 cents Nice clean and simple build by the way..good luck at the local comp Last edited by 6sharky9; 07-24-2014 at 07:12 PM. |
08-07-2014, 06:10 AM | #13 |
i had a DNF at the last event my stupid error. I lost 3 set screws from my drive shaft had lots of fun tho the rig was holding up really well with no issues. I'm running 3s lipo's 65c 6500mah Greddy units |
09-10-2014, 09:04 PM | #14 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
What upper end links did you use? Got a good Canadian supplier for them?
09-11-2014, 08:13 AM | #15 |
I get all my stuff from a LHS here (Pinnacle Hobby) also Great Hobbies has them as for the upper end links i used axial 7x60 and 7x25 rod post (AXA1422 and AXA1429) along with Axial end links i had, you should have some extra with the kit |
PVO_SRT4's G6 Post Build - Similar Threads | ||||
Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thread | cormier33 | Axial XR10 | 132 | 10-26-2014 11:04 PM |
"DIABLO" Ottsix Post Season Build Off! offical build thread | silver falcon | 2.2 Scale Rigs | 21 | 09-06-2014 06:08 PM |
PVO_SRT4's Axial Wraith | pvo_srt4 | Axial Wraith | 14 | 08-17-2014 05:57 PM |
PVO_SRT4's new SCX10 | pvo_srt4 | Axial SCX-10 | 6 | 08-14-2013 09:06 PM |
My first post should be my build | usmc-walker | Axial AX-10 Scorpion | 20 | 06-09-2010 04:56 PM |
