01-14-2014, 02:37 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: Erie
| Hirschowl's G6 build
So I finally got this kit built (my first build) and the electronics installed and it was finally, FINALLY a day where it was warm enough (above 30*) and dry enough to do test run in the backyard on the pile of rocks. I must say it was a blast. Can't wait to run this summer!!!!! The beach at the end of the road is full of perfect size rocks to run this thing. I will have to build a rock garden and trail in backyard. I took a couple of pics to share. I still need to paint the body (again too cold). I bought the paint just waiting for warmer weather. I don't plan on doing anymore big $$ upgrades right away. Just upgrade as things break. May get some steel sliders and want to move the battery onto the slider themselves. I also had the body as low as it could go and the tires were rubbing as you can see in the pics. Will have to find the right spot before running again. |
01-14-2014, 02:44 PM | #2 |
I wanna be Dave Join Date: Feb 2006 Location: r/c crawlin' heaven...
| Re: Hirschowl's G6 build Quote: Those pics are sick! Great job on the build. |
01-14-2014, 07:08 PM | #3 |
Rock Stacker Join Date: May 2012 Location: TeXas
Very nice setup, I'm after those same tires. What color are you going with?
01-14-2014, 07:31 PM | #4 |
Pebble Pounder Join Date: Dec 2013 Location: MARIETTA
Nice looking rig if you have n I t done so already I would recommend reinforcing the holes where cage connects to the body. I took a nasty tumble and would up ppunching the cage through the body. Axial lexan is kinda on the thin side. |
01-14-2014, 10:37 PM | #5 |
Newbie Join Date: Nov 2013 Location: Austin
those wheels look sweet man, mind if i ask what kind they are?
01-15-2014, 12:50 AM | #6 |
Pebble Pounder Join Date: Jul 2012 Location: Folsom, CA
I'm curious about the wheels too. Those look sick on there.
01-15-2014, 03:19 PM | #7 | |||
Mayhem Engineering Mayhem Monsters with the Legendary Beadlock ring. I plan on using a color highlight in the recessed part of the wheel to make it stand out a bit more. | |||
02-01-2014, 10:40 AM | #8 |
| Re: Hirschowl's G6 build |
02-02-2014, 08:23 PM | #9 |
Got my painting done this weekend. Got some good advice on paint some stripes from this great forum. This is my first real paint job. I defiantly see the blemishes. Really enjoyed the painting and masking process except the fumes. I think it came out pretty well. Last edited by Hirschowl; 02-02-2014 at 08:25 PM. |
02-02-2014, 08:29 PM | #10 |
Newbie Join Date: Dec 2009 Location: adell
Looks good I need one of these g6 rigs
02-03-2014, 08:04 AM | #11 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
02-03-2014, 08:21 AM | #12 |
what size hubs did you go with?
02-04-2014, 03:07 PM | #13 |
02-04-2014, 03:26 PM | #14 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
Nice looking paint job,usually the blue and red don't work well together but you nailed it.Nice looking rig now get it dirty!!!!
02-04-2014, 04:02 PM | #15 |
| Re: Hirschowl's G6 build Nice, I was thinking .650 would probably work best. (I've been looking at getting a set of these wheels myself) |
02-04-2014, 04:33 PM | #16 |
Quarry Creeper Join Date: Mar 2010 Location: Massachusetts
How tall are the tires, and 1.9 or 2.2? Sweet rig!
02-05-2014, 07:10 PM | #17 | ||
Thanks. The tires are 1.9's inner 4.65 outer RC4WD 1.9 Interco IROK 1.9 Scale Tire (2) | ||
02-14-2014, 03:29 PM | #18 |
Just a few things I have been working on... Made some upper links using 1/4' brake line, revo rod ends, and 8-32 allthread and some spray paint I had on the shelf. Cut the all thread at 95mm and the brake line at 78.5mm. The fit really well with no change to driveshaft angle. I also put in some C.I. lil'nova foams and move the black bealock ring to the back and move the machined one to the front. I felt the bigger black ring was hiding the beauty in the Mayhem wheels. I can not get these shocks to stop leaking. I have rebuilt 3 times and still leak and haven't even really drivin this thing. Just ordered some pro line scaler shocks from lhs. Will be here next Thursday |
02-14-2014, 03:32 PM | #19 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
I don't know how you built them, but I always goop on some Associated Slime on the lower shock orings as well as on the shaft. Mine didn't leak on the first shot.
02-14-2014, 03:56 PM | #20 |
| Re: Hirschowl's G6 build Yeah, used the slime the first and everytime. The oil is leaking out the top on 3 of the shocks. The spring spacer is getting oil on it so I know its leaking out the top. The bottoms are dry. The oil is making it way down the springs I have read and watched many tip and tricks to get these to stop leaking. I just cant get them to stop.
Hirschowl's G6 build - Similar Threads | ||||
Tamiya Bronco Kit Build; 1st Build | Boxcarcustoms | 1.9 Scale Rigs | 2 | 07-29-2013 07:37 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
