01-22-2014, 07:13 AM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: Downingtown, PA
| Easy battery removal?
Hey guys. I was just wondering, for those of you with the SCX10 that has the removable top, have you figured out an easier way to remove/plug in the battery without having to unscrew the top every single time? Yes I know I can run it without the top, but I love how it looks with that top on there...it just gets annoying needing to unscrew it every single time.
01-22-2014, 07:18 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Easy battery removal?
Put the top on with velcro or use some stealth body mounts such as these; Magnetic Stealth Body Mounts (Silver)- R2 [5068_S] - $19.99 : Black Star Hobbies, Let's Race! or these..... Adjustable Bar Stealth Body Mount (Silver) - R2 [5042_S] - $16.00 : Black Star Hobbies, Let's Race! They use magnets to hold the body to the mounts, work very well as I have used them before. I see they are out of stock but can find them other places as well. |
01-22-2014, 08:05 AM | #3 |
Newbie Join Date: Jan 2014 Location: Hong Kong
You don't have to unscrew the top, Mine is a rubicon and there is a single mount can be clipped between the spare tire and the body. |
01-22-2014, 08:07 AM | #4 |
Quarry Creeper Join Date: Jun 2006 Location: L-Town
U don't need to use the rear body mounts. Use a body remer to make a hole in the back Window of the hard top to go around the rear tire carrier. When u put the pin in the back it will hold the body on just fine.. I'm assuming ur using the jk body with hard top.
01-22-2014, 08:28 AM | #5 |
And that's if he is using the spare. The "stealth" mounts work really well and on a new build / body eliminate body holes and make it more scale looking. They are strong too, you can pick a rig up off the ground by the body when using them. The drift car guys use them thats how I found out about them. |
01-22-2014, 02:46 PM | #6 |
Oh okay thanks guys! Yes, I'm using the spare tire so that sounds like a good idea. Those stealth mounts look great as well...will have to consider those. Thanks for the replies!
Easy battery removal? - Similar Threads | ||||
Battery tray - adjustable easy access concept | zodiaci | Axial XR10 | 21 | 06-10-2012 08:23 PM |
Shock Removal? (and battery question) | monkeyracing | Losi Micro-Rock Crawler | 6 | 11-24-2010 01:05 AM |
finished shock mount\battery tray removal | meathead | Venom Creeper | 1 | 07-21-2009 10:36 PM |
CHEAP EASY Battery Move Suggestion | stomper4x4.com | Losi Mini-Rock Crawler | 0 | 09-06-2008 09:30 AM |
Battery hold down - Free and easy mod | Zardoz | Axial AX-10 Scorpion | 18 | 11-19-2007 06:29 PM |
