07-24-2013, 08:57 AM | #1 |
Newbie Join Date: Sep 2012 Location: Newfoundland
| Johnny Mac's Dingo Build
So my wife gave me a dingo for xmas... And here goes the build...... Packed the axles with waterproof grease. I found putting these together you really need to make sure the bearings are fully seated which required a fair amount of pressure to seat it. Also if you tighten the two half's to tight the gears grind. Took a few minutes to tweak it just right. Shocks... Chassis.... [/b][/b] I decided to extend the wheel base. When I did that the servo would hit the front support between the rails. I had to rig up a new support to achieve full compression of the shocks. Also made up a rear tray for the battery to power the winch and a place to mount the ESC Waterproofed the Axail AE-2 with liquid electric tape I was unhappy with my paint job on the dingo body. I found it very difficult to paint with some of the angles to achieve different colors. A single color on the body would be easy as cake, however doing the body one color and the interior another is very challenging. So... I picked up Prolines Jeep Comanche body. Now its time for custom bumpers and roll cage. A few decals and she will be complete... a few decals sets her off.... Building a custom light bar |
07-24-2013, 11:51 AM | #2 |
Adding led head and tail lights next. And a product from Heyok to operate the light bar lights from my 3rd channel.
07-24-2013, 11:55 AM | #3 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: Johnny Mac's Dingo Build
very nice and like the front bumper, hows the dual motors more power? or does it seem to make the truck have a high COG
07-24-2013, 03:53 PM | #4 |
Thanks. Dual motor does give me more torque. I haven't had a chance to compare it to my buddy's dingo side by side on the same angle to compare the COG. But that's something that I will have to look at.
03-05-2014, 09:58 AM | #5 |
03-05-2014, 10:11 AM | #6 |
Well after the TTC this year I realized the front bumper was garbage.... I love the look of it but it caused me to get hung up on the front corner. Plus after the truck got rear ended by a fly away Stampede (thanks azuran73 ...lol) I had to build a new rear bumper. Had a few hours last night so I built a new rear bumper. I shortened the length a little and put in two middle supports. Old Rear... The front I shortened the sides, cut off all the top section and created a new one. It does need a slight adjustment. Now to start painting .... Old Front... |
03-05-2014, 10:35 AM | #7 |
Rock Stacker Join Date: Mar 2014 Location: Conover, NC
Sorry for my question but I'm new to all this... What material are you using for the bumpers and what you weld with? VERY nice rig!!! |
03-05-2014, 10:31 PM | #8 |
It's very easy, just like soldering. I used brake line from NAPA (it's cheap and easy to bend). Mini pipe cutter like for cutting copper pipe is awesome for making smooth cuts. A little sandpaper to clean your joins. Get brazing flux and silver solder. I fond it very hard to find and it wasn't cheap. Use map gas and a proper map torch. It's a yellow can. I got the torch and igniter as a kit. Make sure your joint is smooth and clean. Place some flux in it and then heat. When it turns nice a red touch the solder and bammmm. Sweetness. Lol. It's nice to have one of those third hand things too. They are cheap at princess auto. I found the magnets at princess auto was awesome too for holding joints together. |
03-06-2014, 12:48 AM | #9 |
| Re: Johnny Mac's Dingo Build |
03-06-2014, 05:43 AM | #10 |
Newbie Join Date: Dec 2013 Location: London
Superb, if i didnt have 3 left hands, i'd give that a go |
03-12-2014, 01:45 PM | #11 | |
Pebble Pounder Join Date: Feb 2011 Location: Office Space
| Re: Johnny Mac's Dingo Build Quote:
Johnny Mac's Dingo Build - Similar Threads | ||||
Johnny Cool Guys in Euless | du4x4 | Texas | 6 | 01-28-2011 03:22 PM |
Johnny Cash would have been 78 today | dragit | Chit Chat | 22 | 02-27-2010 08:26 PM |
Johnny Greaves Airing it out | HITMAN | Chit Chat | 29 | 01-06-2010 08:13 PM |
