Thread: SCX10 Noise coming from the axle
Old 03-01-2014, 09:57 AM   #1
Default SCX10 Noise coming from the axle
I hear the noise only when driving up and down of something like in the video.
https://www.youtube.com/watch?v=ljeI...e_gdata_player
Anyone can help me? ??
UNDEAD_DC is offline   Reply With Quote
Old 03-01-2014, 10:12 AM   #2
666
MODERHATER™
666's Avatar
Default Re: SCX10 Noise coming from the axle
Take it apart and have a looksie!
666 is offline   Reply With Quote
Old 03-01-2014, 10:19 AM   #3
Only way to tell is to tear into the axle and inspect. It is either the locker or the gears.
2JSC is offline   Reply With Quote
Old 03-01-2014, 10:31 AM   #4
What gears? The one on the motor or the ones in the axle?
Old 03-01-2014, 11:13 AM   #5
Disconnect the driveshafts and if the noise still happens, chances are its in the tranny. And vice versa if the noise stops, more likely the axle(s). As was said, only proper way is to start some disassembly and have a look at all your gears.
If you haven't done the bearings in awhile or replaced the stock gears with the hardened versions, it may be a good idea to do so. The stock gears will deform easily with even a heat gun applied to them... found that out the hard way.
Meatwad is offline   Reply With Quote
Old 03-01-2014, 11:38 AM   #6
Well this is pretty crap...
I think I am going to have to buy new gears, its coming from the gears that go from the big gear to the drive shafts so you have motor with a gear on it that is on a big gear, those are not the problem but the ones that come after those.
Can I just keep drivin? Or as long as it takes to get the new ones? Cuz il have to order them prob.
Old 03-01-2014, 05:03 PM   #7
It's the gears in the tranny then right? the ones that are inside the plastic case. You could keep running it i probably would, but you are going to need new gears, and there is a chance youll burn out the bearings, but a new set is probably $20, you should probably order them with the hardened tranny gears in any case..
autonomous is offline   Reply With Quote
Old 03-01-2014, 05:08 PM   #8
OK First I was stupid enhough to just google tranny and klick image, sure not what im looking for.
So if i buy such a plate thingy why dont i buy one of these?
https://store.rc4wd.com/mobile/product.asp?itemid=2463
Is that smart plan? Or nor and why or why not? Anyone has excperience with one? And wich is best to buy if you also look at price?
And about these bearings? Why do they go broken? They melt? And wich bearings would you suggest?
Edit2:
I see alot of people that dont have the plastic cover over their gears that come from the motor an the big gear thing. Why is that?
And i think my slippery clutch (is that right how i write it) isnt working it wont just slip motor looses it.
And if the engine cant win it how bad is it to keep trottling?
Last edited by UNDEAD_DC; 03-01-2014 at 05:39 PM. Reason: stupid not well thinking reaction.
SCX10 Noise coming from the axle - Similar Threads
Axle gear noise canadianbacon Axial SCX-10 4 10-20-2012 09:40 PM
Clicking noise coming from transmission-Help please promatchrcr Team Losi Comp Crawler 13 01-20-2010 03:35 PM
axle noise IDnewcrwlr Axial SCX-10 7 09-18-2009 09:41 PM
Axle Noise loanshark Tamiya TLT Crawlers 4 03-02-2007 02:43 PM
