04-25-2014, 09:21 PM | #1 |
Rock Stacker Join Date: Dec 2013 Location: canada
| motor overheating ,doesnt have power
I have a scx10 with a stock 27t motor,I put on 1.9 beadlocks with the proline tsl xl tires (the tall tires ,121mm)now the motor is running very warm almost too hot , I was running a 12t pinion then I changed it too a 18t pionion ,still runs hot ,has no power to climb over logs , Front rims 3.50oz weight on each wheel Rear rims 2oz weight on each wheel Could it be to much weight so the motor is lagging ? Thanks |
04-25-2014, 09:52 PM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
| Re: motor overheating ,doesnt have power
The larger pinion (18t) will give you more top speed, but will also heat your motor up faster. May want to go back to the 12t to put less strain on your motor.
04-25-2014, 10:01 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
The motor might just be on its last leg. Go back to the smaller pinion. I run a 14t with a 20t and have 4.75" toes without problems but the motor is still new.
04-25-2014, 10:33 PM | #4 | |
| Re: motor overheating ,doesnt have power Quote:
04-25-2014, 10:50 PM | #5 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
Just burn it up and have fun. The stock cans are cheap and readily available. There is no fun in driving like grandma!
04-25-2014, 11:58 PM | #6 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
the stock motors are not known for being super reliable or known for speed or torque. maybe go with a higher end motor like a holmes hobby motor. im running a 27t rebuildable motor with pitbulls on my truck. 218g up front and 186g in the rear.
04-26-2014, 01:08 PM | #7 | |
2oz in each front wheel 1oz in each rear wheel I put on a 12t pinion , It works better now It was fine when I was running the stock trep tires ,had 1.50oz on each front wheel ,and no weight in the rear wheels ,with 12t pinion | |
04-26-2014, 09:03 PM | #8 |
Just tryed it out ,I remove some weights and put back on 12t pinion ,now it works better
motor overheating ,doesnt have power - Similar Threads | ||||
Wraith motor overheating | Spudnut | Axial Wraith | 17 | 06-02-2013 11:08 AM |
Motor overheating.... | Rockrash34 | Axial SCX-10 | 15 | 04-25-2013 10:49 AM |
Motor overheating/ diff heat | LCC4TWENTY | Team Losi Comp Crawler | 15 | 07-30-2009 12:51 PM |
Overheating & Power Issues - SuperRooster + Titan 775 + Huge Tires | jtice | Electronics | 7 | 03-26-2009 03:48 PM |
Cheapest brushless motor available? (doesnt have to be for crawling) | DKNguyen | Electronics | 5 | 05-30-2007 08:29 PM |
