Thread: driveshaft pins
Old 04-25-2014, 11:04 PM   #1
Default driveshaft pins
So i took my scx 10 out for a first run after i put all my electronics in and i lost 2 pins that hold the drive shaft on its kinda of a silly pin set up are you suppost to glue them in or how else do you get them from sliding out because there is nothing that holds them in
insutama is offline   Reply With Quote
Old 04-26-2014, 12:10 AM   #2
Default Re: driveshaft pins
did you forget the plastic rings that go over the pins?
some87 is offline   Reply With Quote
Old 04-26-2014, 08:59 PM   #3
Which part came loose ? For screws that go into metal use blue locktite and let it dry for 24 hours.
im gunna crawl is offline   Reply With Quote
Old 04-26-2014, 09:24 PM   #4
Or 20 minutes. I've use blue loc tite on go fast and torquey scalers forever and used it as fast as 20 minutes later...and no problems...actually kinda hard to remove...especially on grub screws and driveshaft thru pins...its still a lil hassle to get off lol..you really dont need to wait 24hours.
Sent from a whiskey downer beer pounder's shop
Undefined is offline   Reply With Quote
Old 05-02-2014, 05:21 PM   #5
hey sorry for the long reply but i was out of town anyway the parts that keep falling out are AX30166
Old 05-02-2014, 05:22 PM   #6
i think i must have forgot the rings
Old 05-02-2014, 05:45 PM   #7
If ya can't find the metal rings you can get by with a few layers of heatshrink tube.
old man 52 is offline   Reply With Quote
driveshaft pins - Similar Threads
Pins? Tgreer Losi Mini-Rock Crawler 5 08-30-2011 12:14 AM
Pins punishermustang Venom Creeper 14 02-07-2011 11:26 PM
Driveshaft pins... Duuuuuuuude Team Losi Comp Crawler 5 04-18-2010 09:33 PM
Yoke pins / screw pins cyberdog General Crawlers 2 05-27-2009 03:06 AM
Yoke pins / grub pins Yawzer General Crawlers 5 01-09-2008 11:28 AM
