05-25-2014, 10:44 PM | #1 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
| G6 questions
So i traded for a used g6 last week, and its in "ok" condition. This is my first scaler so I'm a noob to this world. Ive been trying to research some builds on here and specifics with them and i haven't found much. I don't know if I'm just mission the threads, but when i search g6, it comes up saying no results so whatever. Im looking for a few answers. Does anyone make an aftermarket 3 link kit to run CMS and panhard specifically for the g6 or will the other scx kits work. I wasn't sure because i knew the g6 wheel base is slightly smaller. Ive seen the Vp 4 link kits which ill go with if i have no luck with the CMS. Another question i had was on Lift kits, any advantages other than being able to fit larger tires? i would think it makes it too top heavy and tippy Other than that i was hoping some of y'all would just share your thoughts on mods for the g6/scx10's or any advice to the noob to the scaler world. |
05-25-2014, 11:49 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: G6 questions
The g6 is just another scx10. I would lengthen the wheelbase to the honcho length. Don't do lift kits they topple over way too easy. You can do different shocks, which is what I do to make it flex more and have more contact patch on the trail. Vanquish makes a kit for chassis mounted steering with a 3 link w/pan hard bar . I personally think you don't need cms. Get a high torque steering servo mount on the axle and use 8 degree knuckles and c hubs, with their axles or do the Xr mod for steering. Put some proline tsls on it.the small ones, not the xls. Search vanquish products. Last edited by im gunna crawl; 05-26-2014 at 12:00 AM. Reason: More info. |
05-26-2014, 05:23 AM | #3 | |
| Re: G6 questions Quote:
05-26-2014, 10:39 AM | #4 |
Newbie Join Date: Jun 2013 Location: Lakeside
Leave the stock shocks on it they work good. I get as much flex out of the stock shock as my son does with 110 mm kings and I sit lower. Lots of flex it not always a good thing. Make the rig unpredictable. I used the vp cms kit and 3 link on my g6. Works good. I also installed a jevne racing cms brick plate. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
05-26-2014, 11:05 AM | #5 | |
RCC Addict Join Date: Feb 2008 Location: your back yard
05-26-2014, 07:09 PM | #6 |
| Re: G6 questions |
G6 questions - Similar Threads | ||||
lipo questions with charger questions can you all help | champ198 | Electronics | 16 | 05-02-2013 01:24 PM |
lipo questions with charger questions can you all help | champ198 | Electronics | 0 | 04-30-2013 05:54 PM |
Questions Questions | mgauger | Newbie General | 14 | 02-04-2011 02:59 PM |
2 questions. | Brandxman | Tamiya Clod Buster | 3 | 09-11-2009 04:11 PM |
Questions questions questions quest qowirnl | RYY | Newbie General | 11 | 10-04-2006 08:18 PM |
