06-09-2014, 01:21 PM | #1 |
| Front 4 link question
I have question for anyone that has put together their truck with the Axial 4 link truss and custom upper links with Revo rod ends. Mocking everything up yesterday, it was pretty obvious that the Revo rod ends were too big to fit underneath the stock servo plate on the front end. If I cut the stock servo plate or get the Wraith plate, does that provide enough clearance for the Traxxas rod ends to move freely? If not, I'm thinking of getting a Level 3 4 link mount for the front of the truck.
06-09-2014, 05:13 PM | #2 |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
| Re: Front 4 link question
I actually have a wide 4 link mount by level3 to get rid of, let me know if you're interested. Pretty sure that would get you away from the plate, let me go make sure revo rod end balls fit in the mount, as I know they don't squish as axials do.
06-09-2014, 09:46 PM | #3 |
Rock Stacker Join Date: Sep 2013 Location: Vancouver
I used traxxas Jato rod ends. They are longer, but not as "big".
06-09-2014, 10:19 PM | #4 |
| Re: Front 4 link question |
06-10-2014, 02:30 PM | #5 |
Rock Stacker Join Date: Apr 2013 Location: Auburn, Ca
^^ Second that. I made a servo plate out of .125" thick aluminum in the same shape as the stock plate then I notched out where the rod ends would be hitting. Never had a problem with that set up. Four link in the front is better than 3 all day long.
06-10-2014, 02:36 PM | #6 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
Or use some thin spacers under the plate. I had to space mine up to make my long servo arm work with out hitting the pumpkin.
06-10-2014, 03:09 PM | #7 |
Well, luckily I have 2 trucks I'm building so I can cut the servo plate on one and run the Level 3 mount on the other. |
06-11-2014, 04:32 AM | #8 |
Newbie Join Date: Oct 2013 Location: Poland
06-11-2014, 12:54 PM | #9 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: Front 4 link question Quote:
EDIT: During my lunch break I added a single 2mm spacer between the plate and screw holes on each side of the axle. Now it's juuuuust right! Last edited by DowntownScience; 06-11-2014 at 04:14 PM. | |
Front 4 link question - Similar Threads | ||||
Trail Honcho front 4 link question | road_rascal | Axial SCX-10 | 3 | 03-01-2014 06:50 PM |
front axle link question | crazy nick | Axial SCX-10 | 1 | 12-27-2013 08:50 AM |
Vp front link question | Mysterious | Axial XR10 | 10 | 08-09-2012 09:08 AM |
3 link front 4 link rear? | MaxxMc | Losi Mini-Rock Crawler | 7 | 04-03-2009 09:31 AM |
IFS w/ 4 link front and 3 or 4 link rear. | T-Man | Traxxas Crawlers | 6 | 10-26-2004 07:28 AM |
