06-10-2014, 01:42 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| What kind of Grease to you use an axles?
I got a secondhand dingo. Took it all apart new bearings. Coated everything with marine grease. Doesn't have a ton of use. Grease is pretty much gone. Bearings are shot and the ring gear teeth are pointed. Maybe I need to fill the whole case with Grease. Thought that would cause a lot of drag. So I didn't do it the first time. Maybe try white lithium grease?? we you guys use?have a good one |
06-10-2014, 01:59 PM | #2 |
| Re: What kind of Grease to you use an axles? |
06-10-2014, 02:06 PM | #3 |
Rock Crawler Join Date: Feb 2014 Location: ?
06-10-2014, 02:40 PM | #4 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
06-10-2014, 02:56 PM | #5 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I don't even know what mine is but it's red and has little white things in it. Seems to work good! |
06-10-2014, 07:19 PM | #6 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
That's not grease.....that's caviar |
06-11-2014, 03:30 AM | #7 |
red and tacky i tried first. washed away just like the marine grease did. did you guys pack the axle full? i coated everything
06-11-2014, 07:13 AM | #8 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
| Re: What kind of Grease to you use an axles? Ive uses red and tacky and marine grease and yeah they both wash out. But it takes a few runs. But IMO its just part of the routine maintenance now. Any time mine sees any kind of extended time around a lot of water or mud i pull it down clean, clean out the housings and re grease everything. |
06-11-2014, 08:17 AM | #9 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
Lucas Red N Tacky!
06-11-2014, 10:49 AM | #10 |
Newbie Join Date: Dec 2013 Location: Fresno, CA
I would have to agree to use Red N Tacky and Marine Grease. Also make sure to rebuild the axles after a long day of use.
06-11-2014, 11:02 AM | #11 | |
| Re: What kind of Grease to you use an axles? Quote:
06-11-2014, 12:43 PM | #12 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
06-11-2014, 01:27 PM | #13 |
have yet to try white lithium
06-11-2014, 01:46 PM | #14 | |
Moderator Join Date: Jan 2004 Location: chicago
ive never had green grease wash itself out, and im not at all shy of water. | |
06-11-2014, 02:32 PM | #15 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
Anyone ever installed a zerk into the housing?
06-13-2014, 03:51 AM | #16 |
Rock Stacker Join Date: Dec 2013 Location: San Jose
06-13-2014, 08:22 AM | #17 |
Newbie Join Date: Apr 2011 Location: portland
I use a waterproof Belray grease that I use on my motorcycle with great success. Pack the pinion gear and keep the ring gear coated. Pack the ends of the shafts by the bearings Devious PowerSports ,Tyler |
06-13-2014, 08:38 AM | #18 |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
| Great grease, great guy. Sent from my iPhone using Tacos |
06-13-2014, 09:58 PM | #19 |
website is gone
06-13-2014, 10:21 PM | #20 |
I'm another Lucas red and tacky user. Mainly because it's already in the frequently-used 1:1 grease gun. It definitely doesn't stay on the gears for long. It's really meant more for ball or roller bearings than gears, but with frequent lubrication application it works well. There is no need for the zerk fitting, just drill a hole and thread in a 3mm, or 4mm, or 5mm grub screw. Then use a needle fitting on a grease gun up against the hole. There is even room in the trans case between the upper and idler gear for a 3mm grub screw so it may get greased as well. All my scalers play submarine on occasion, so I do use the grease gun to fill, and purge, the axles. Yes this adds a little drag, but it's not so much as to worry about. What I do worry about is corrosion, so I'm particular to grease the drivetrain after a day of submerged playing. I'll often see the water get forced out the pinion and axle bearings as the axles is packed with fresh grease. |
What kind of Grease to you use an axles? - Similar Threads | ||||
Universal axles (Axial)... grease or no grease | TacoCrawler | Axial SCX-10 | 15 | 11-14-2013 12:27 PM |
what kinda of grease is everyone using in there axles | Kentuckcrawlers | Venom Creeper | 2 | 11-07-2010 10:21 AM |
grease your axles | JesterSpec | General Scale Talk | 1 | 08-06-2010 01:33 PM |
Using grease to waterproof axles? | oxyjansen | Tamiya CR-01 | 16 | 11-23-2009 01:37 PM |
Filling axles with Grease? | Sasquatchbagger | Axial SCX-10 | 10 | 03-31-2009 03:36 PM |
