Thread: Axial Hi-Clearance Knuckles
Old 07-19-2014, 11:31 PM   #1
I joined the Band!
Default Axial Hi-Clearance Knuckles
Anyone know of a tutorial on these things I've got them installed but I can't seem to figure out how to run my steering linkage now. This is my first SCX10 so yes I'm a newb at this. Thanks for the help.
Allen
forsfed86 is offline   Reply With Quote
Old 07-20-2014, 12:25 AM   #2
Default Re: Axial Hi-Clearance Knuckles
CMS or axle mounted servo ?
I cannot comprehend the mechanical difficulty
so...
Let me google that for you
> " Images " if reading is too much effort
> " Videos " if pictars bring no joy
a search on this forum
TacoCrawler is offline   Reply With Quote
Old 07-20-2014, 01:24 AM   #3
Natedog's Avatar
Allen
Here's how I set mine up: Natedog's Honcho kit build
Old 07-20-2014, 01:44 AM   #4
I joined the Band!
so...
Keep your smart aleck comments to yourself. If you don't having anything useful to say don't say anything.
Old 07-20-2014, 01:46 AM   #5
I joined the Band!
Nate,
Thanks for the response. I'm still using the axial aluminum steering up grade that comes with the G6 kit. I guess I will need to upgrade to a bent style steering linkage?
Thanks again
Old 07-20-2014, 09:54 AM   #6
Nate,
Thanks again
This titanium linkage is made specifically for the axial high steer knuckles...Titanium Steering Linkage for SCX10, Blue Monkey RC
There is a box where you can choose the design of the linkage (it's under "Available Options") Just click on "Axial high steer knuckles"
Johnnysplits is offline   Reply With Quote
Old 07-20-2014, 10:38 AM   #7
I joined the Band!
Thank you Johnny
Old 07-20-2014, 02:02 PM   #8
Make your own links. You can make custom bends if needed, make a few mistakes and have still spent less cash than buying any prefabbed set...
Meatwad is offline   Reply With Quote
Old 07-20-2014, 02:30 PM   #9
it was useful... to those whom make an effort to help themselves.
obviously you're offended... because you don't.
Most everything you might ask here...
has been asked and answered.
if you take the time to search and read.
If you don't wish to... that's on you
so maybe post in the newbie general folder
where you would be removed from all criticism.
Don't blame me for your shortcomings
but so that you will be happy...
I will refrain from commenting in your future threads.
Old 07-20-2014, 04:59 PM   #10
I had to run the short drag link to the bottom of the left knuckle. Then I had to run the long tie rod top to top behind the servo horn. It was toe in at first but two of the spacers from the upgrade kit made the tires toe out just slightly. I ended up breaking the rod end and made my own from 8/32 all thread and a small tube I found at the lhs. Just had this same issue about a week ago so I hope my input helps.
jsadvar is offline   Reply With Quote
Old 07-20-2014, 07:11 PM   #11
I joined the Band!
Actually, not that I have to justify myself to you, I did research before I posted. Being new to this and not knowing exactly what to search for I didn't find what I was looking for. Inevitably there seems to be that one person, like yourself, who feels like they must be a jerk to someone who is new. I guess it makes you feel better about yourself.
Thank you from refraining in the future, if you had done so in the first place I wouldn't be wasting my time typing this to you now.
Old 07-20-2014, 07:15 PM   #12
I joined the Band!
Thanks, for the great info everyone. It's definitely helped! I think I've got it figured out.
Axial Hi-Clearance Knuckles - Similar Threads
Axial Hi-clearance knuckles Garry Axial AX-10 Scorpion 16 12-28-2010 11:49 PM
