Thread: front wheels surging at low throttle
Old 07-29-2014, 02:24 PM   #1
Default front wheels surging at low throttle
When I hold my scx in air and run throttle at very low speeds the back wheels turn super slow and the front wheels kinda surge like almost pulse they stop then jump ahead then stop then jump ahead I hope this makes sense I made sure the notches on drive shafts lined up anything else I could try? Should I open up the front differential and take a look maybe I screwed up when I originally assembled it
insutama is offline   Reply With Quote
Old 07-29-2014, 02:47 PM   #2
Default Re: front wheels surging at low throttle
Compress the front suspension and try it again. Odds are the driveline is near its max operating angle.
WHITE-TRASH is offline   Reply With Quote
Old 07-29-2014, 03:05 PM   #3
Are you running different driveshafts or longer shocks? The best way to make that stop is clocking the axle forward with a spacer in the links just a little bit (that's only if you're using aluminum links). Now say if you have aftermarket shocks then anything over..100mm can cause the driveline to bind a little bit. (Yes I've had it happen to me until I bought a droop kit). On my scx10 jeep I have 120mm shocks and even on a droop kit it made everything bind so I got a long threaded grub screw and put a spacer in the upper links..this stopped the binding and made the driveshafts turn at a much better angle (however I hate the ride height with those shocks and will be changing them out very soon).
axial 4x4 crawler is offline   Reply With Quote
Old 07-29-2014, 03:24 PM   #4
X2!
Btw white trash we live in diff tri cities!!!
I live near Bristol motor speedway lol...
sic1to is offline   Reply With Quote
Old 07-29-2014, 03:48 PM   #5
okay i just tried messin with it and when i compress the socks it makes no differance still surges when i go full throttle the differential makes slopping around sound so i think im gonna have to open it up and take a look if somthings wrong
Old 07-29-2014, 06:30 PM   #6
Possible play in the locker.
Johnnysplits is offline   Reply With Quote
Old 07-30-2014, 06:55 AM   #7
For the driveshaft's, there's actually 4 points that need to match, not just the two notches on the shaft. The other two points are the pins in the couplers.
Both the couplers and the notches should all be aligned with each other.
summerof95 is offline   Reply With Quote
Old 07-30-2014, 07:21 AM   #8
Sounds like your gear mesh is incorrect, make sure your pinion bearings are pressed all the way into the housing. If they are not, it will make the ring and pinion mesh to tight which will be noisy and notchy when running it.
HDMM is offline   Reply With Quote
Old 07-30-2014, 09:47 AM   #9
hdmm are you talking about inside the dif ?
Old 07-30-2014, 12:28 PM   #10
Driveshaft phasing. Make sure the pins in the joint are lined up the same as well as the notches on the shafts
Axial SCX10 Dingo Axle Chatter & Fix: http://youtu.be/acrSdzzniiw
e30nate is offline   Reply With Quote
Old 07-30-2014, 12:45 PM   #11
The same topic is being discussed every week
ricksonchow is offline   Reply With Quote
front wheels surging at low throttle - Similar Threads
Sidewinder v3 surging throttle B94Cast Electronics 22 03-23-2014 09:39 AM
3s low throttle vs. 2s Nicolasmj Electronics 10 08-27-2013 04:12 PM
pics of FRONT LOW LOW wanted dhoffroad General Crawlers 16 02-21-2006 08:10 PM
surging/front axle not engaging Jeepman97tj General Crawlers 1 01-02-2006 02:03 PM
Surging when in low range/ axles won't shift theone13 General Crawlers 3 09-02-2005 09:34 PM
