08-06-2014, 03:53 PM | #1 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
| Xr10 rear lockouts on scx10
I am in the process of tgathering parts to do the xr steering mod on my scx10. I traded my vanquish stage 1 kit for a new xr10 axial aluminum stage 1 kit. I will be using the c-hubs and knuckles, but can I use the rear lockouts? I traded my rear lockouts with the kit. Thanks in advance for your replies |
08-06-2014, 09:04 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: Xr10 rear lockouts on scx10
Please show it, I want to do this mod.
08-06-2014, 10:07 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
To do the XR mod on the rear, you need to run Wraith lockouts on the rear with (2) long side XR10 rear axle shafts ( good luck finding those ). That's if you are doing the XR width (wide) mod. Otherwise, you would just use SCX10 lockouts in the rear, XR ones won't work.
08-07-2014, 05:01 AM | #4 |
I want to keep the stock rear end, not doing the xr mod there. Just seeing if the xr rear lockouts work. Guess I gotta find some scx10 ones again then. Thanks! Sent from my SAMSUNG-SGH-I747 using Tapatalk |
08-07-2014, 05:59 AM | #5 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
The xr rear lockouts will narrow the track width I used them to narrow the rear axle on my class 1 jeep. To make the rear axle wider you would need to use wraith lockouts. |
08-07-2014, 06:10 AM | #6 |
They worked with the stock scx10 rear axle shafts? If they fit, i may just use them and deal with the narrower rear axle How much narrower is the rear trac vs front? |
08-07-2014, 06:14 AM | #7 | |
| Re: Xr10 rear lockouts on scx10 Quote:
I narrowed the rear shafts too. I had narrowed the front already so they are about even now. It's less than 7" wide at the outside of the tires. You can see the ruler in the pic. | |
08-07-2014, 06:20 AM | #8 |
The front and rear axles are the same width then?
08-07-2014, 07:23 AM | #9 |
| Re: Xr10 rear lockouts on scx10 |
08-07-2014, 07:25 AM | #10 |
Sorry to ask so many questions, but how'd you manage to do the XR mod and make the track narrower? I'm following this "narrow" version but it still adds 1/2" to the width How to do the narrow XR10 mod to Axial axles I do have my stock plastic lockouts from the wraith axles that could add rear width to the track to match the "narrow" front axle |
08-07-2014, 08:20 AM | #11 |
I'll have to take pics, I machined down the chubs and shortened the housing ends and used beef tubes. You can make the axle stock width with the xr mod as well. Just trim the chubs down. |
08-07-2014, 08:25 AM | #12 |
| Re: Xr10 rear lockouts on scx10 This is before I narrowed the rear. |
08-08-2014, 07:24 PM | #13 | |
Quarry Creeper Join Date: Dec 2011 Location: Us
I'll be posting these up in the "New Products" thread shortly. They achieve a true SCX10 stock width using Wraith chubs and knuckles They do require some machining of the Wraith chubs, but i will be offering them as a package. (Tubes and machined chubs) Feel free to PM me with any questions. | |
08-08-2014, 08:10 PM | #14 | |
Nope this jeep has regular beef tubes. I made this axle before I won those from BDN. This axle in my black jeep is narrower than stock. | |
Xr10 rear lockouts on scx10 - Similar Threads | ||||
XR10 with rear Wraith lockouts | SDheavymetal | Axial XR10 | 11 | 01-21-2012 01:17 AM |
wraith rear axles/lockouts on xr10? | jebster | Axial XR10 | 7 | 12-02-2011 06:06 AM |
