08-07-2014, 03:12 AM | #1 |
Rock Stacker Join Date: Feb 2006 Location: Home
| Front Axle judder
Quick question Brand new scx10 g6 kit, built it yesterday and took it out for a very short test earlier, but the front axle seems to judder at certain times There is a occasional clicking noise when driving, but if you lift the truck clear of the ground and put about half throttle the front axle judders badly where the rear turns at a constant speed. It doesn't appear to be an issue with the transmission as the rear axle isn't effected when the front is juddering. Any suggestions as to what could cause this? |
08-07-2014, 03:23 AM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Hows the pinion angle at the front diff?
08-07-2014, 03:29 AM | #3 |
| Re: Front Axle judder
It is a bit steep for my liking, i had to add the addition shims to the lower links to make room for the servo, but the driveshaft appears to be working within its operational limits.
08-07-2014, 04:08 AM | #4 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
Instead of adding shims to the lower links, you can remove the cross member in front of the servo. Or grind some off if you're using it for the battery plate, just to make the servo horn clear the cross member. I've actually added a couple of shims to the upper link, clocking the axle a bit forward. Following building instructions from Axial leaves the axle clocked backwards, creating an ugly angle for the drive shaft. |
08-07-2014, 04:35 AM | #5 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
Is your front driveshaft lined up end to end, I believe there are marks on them if not just make sure the pins at both ends line up.
08-07-2014, 06:44 AM | #6 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Here is the cross member notched to allow the servo to pass. Making your lower links longer to accommodate the servo clocked the axle back . Resulting in harder pinion angle. Pull the spacers and notch the cross member. Good luck. |
Front Axle judder - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
LNC front axle teardown/axle shaft removal guide? | LowLock | Team Losi Comp Crawler | 1 | 05-22-2011 09:31 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
