Thread: Needing custom build opinions
Old 08-15-2014, 08:35 PM   #1
Default Needing custom build opinions
Hey guys I'm doing a custom build. I'd like to replicate an old stepside chevy but I'm wanting a mud racer to. I thought about using a k2-3L chassis but it looked to thin and easily bendable.. so I'm thinking about using an axial Scx10 chassis with wraith axles and a proline chevy body but I'm wanting to run leafs.. can anybody help with that?
jacob.guthrie.96 is offline   Reply With Quote
Old 08-15-2014, 08:36 PM   #2
Default Re: Needing custom build opinions
this is what I'd like to replucate
Old 08-15-2014, 08:37 PM   #3
this is the mud racer
Old 08-15-2014, 09:04 PM   #4
To get the truck to look like the first pic, I would use scx axles and 1.9 Tsl's in xl flavor. Clod body, not sure about the step side though.
lonleycreeper is offline   Reply With Quote
Old 08-15-2014, 09:09 PM   #5
Well I found an actual stepside body but what about the mud racer.. I've got wraith axles but should I use the scx10 chassis?
Old 08-16-2014, 01:24 PM   #6
Mud racer- SCX axles, trans, Clod body, and RC4WD Mud Bashers (rice and cane copies...) mounted on a narrow wheel.
89redranger is offline   Reply With Quote
Old 08-19-2014, 02:21 PM   #7
I was Guna use wraiths Cuz what mud truck do you see with the tractor tires inside the fender wells? You don't Cuz they are to big and you need the width to turn
Old 08-19-2014, 03:23 PM   #8
It's largely dependent on which body you want to use. Ever seen the width difference between a Clod sized body and Wraith axle? Better yet, you ever seen what 5.5" tall 2.2s look like under a Clod body with Wraith axles? If you're shooting for the larger Savage XL or T/E-Maxx bodies Wraith axles will probably be just about right. I am currently piling parts for a Ranger based mud rig to tow behind my Mog when completed. The Ranger body itself is around 6.5" wide, 9.5" wheelbase, and 16" long. In my case, SCX10 axles on 1.9 Mud Bashers will fit the bill perfectly. Plans are- Tamiya Land Freeder body (Ranger copy), some sort of mega truck inspired TVP chassis for simplicity, an SCX10 trans with RRP steel gears, VXL on 3s, LOTS of fender cutting to mimic the race style 1:1 mega trucks, and a 2" wheelbase stretch (11.5" final WB).
Needing custom build opinions - Similar Threads
Custom new bumper for my Honcho. Opinions wanted. DieCastoms Axial SCX-10 6 05-12-2013 12:32 PM
budget MRC pro roller build - Newbie needing help! Speeding Losi Mini-Rock Crawler 21 06-22-2011 08:34 PM
your opinions on my build 4goodbuys2 1.9 Scale Rigs 5 04-12-2010 05:18 AM
