09-01-2014, 07:14 PM | #1 |
Pebble Pounder Join Date: May 2014 Location: Escatawpa
| Servo chattering
Just got a new radio for my scx10 and noticed that the servo just chatters really bad. Any suggestions? Sent from my iPhone using Tapatalk |
09-01-2014, 07:17 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: Servo chattering
Check where it plugs in to the receiver. Has to be a power issue
09-01-2014, 07:20 PM | #3 |
Ok let me look Sent from my iPhone using Tapatalk |
09-01-2014, 07:25 PM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Servo chattering What radio? I had this issue awhile back with my Futaba 4PL and a futaba analog servo in one of my older cars. There was a setting wrong on the transmitter, it was set to "high speed" for the servo which was causing it to chatter bad and get hot. I had to call Futaba to figure this out. |
09-01-2014, 07:26 PM | #5 |
I got a futaba 4PLS Sent from my iPhone using Tapatalk |
09-01-2014, 07:29 PM | #6 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
What kind of servo is it.
09-01-2014, 07:31 PM | #7 |
I am Running the stock scx10 servo as well Sent from my iPhone using Tapatalk |
09-01-2014, 07:35 PM | #8 |
It's the AS-3 digital servo Sent from my iPhone using Tapatalk |
09-01-2014, 07:40 PM | #9 |
Just unplugged and plugged the servo and it's still chattering Sent from my iPhone using Tapatalk |
09-01-2014, 07:50 PM | #10 |
Did you check the settings on the radio as mentioned? I've never had my stock servo chatter. But some of my savox servos did.
09-01-2014, 07:55 PM | #11 |
Yeah what things do I need to Mess with on the radio? Sent from my iPhone using Tapatalk |
09-01-2014, 08:03 PM | #12 |
Ok just messed with the servo speed and it didn't work Sent from my iPhone using Tapatalk |
09-01-2014, 09:13 PM | #13 |
And you haven't changed anything else and are sure a connector hasn't pulled apart from itself or anything.
09-01-2014, 09:59 PM | #14 |
when you say chatter, do you mean glitch ? How old is the servo (meaning use) ? Often the plastic bushings on the output shaft will fail and this could cause a chatter in the steering linkage. The plastic bushings can be replaced with ball bearings but it's probably cheaper to just get a different servo that already has bearings on the output shaft. Now if it's a glitch instead... is there a chance the servo got wet ? The as-3 servo is not waterproofed. and will glitch or even fail if moisture gets inside. |
09-01-2014, 11:24 PM | #15 |
RCC Addict Join Date: Aug 2007 Location: Seattle
SPM1600 Spektrum Voltage Protector (Servo Glitch Buster) I needed this with my 3pk / spektrum setup. |
09-02-2014, 04:44 AM | #16 |
It's practically new. It's Hasn't been wet. It basically makes a weird chatter noise when I turn the wheel but never gets hung up or does any movement on its own. When I let go of the steering it stops Sent from my iPhone using Tapatalk |
09-02-2014, 04:45 AM | #17 |
I also checked the connectors and haven't changed anything else Sent from my iPhone using Tapatalk |
09-02-2014, 04:46 AM | #18 |
The servo is about month old. Not many hours on it Sent from my iPhone using Tapatalk |
09-02-2014, 05:33 AM | #19 |
Rock Crawler Join Date: Feb 2014 Location: ?
It's a cheap servo. I burnt up an Axial servo in about one day. Sometimes there is no fix for it except to replace it.
09-02-2014, 05:40 AM | #20 |
I'm betting $5 a glitch buster fixes it. Any halfway decent hobby shop should have one in stock. PayPal ready. |
Servo chattering - Similar Threads | ||||
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 106 | 10-20-2013 02:16 AM |
Front chattering! | biomanz | Axial SCX-10 | 7 | 05-01-2013 07:06 AM |
Sensored chattering. Help! | Sneakretly | Axial Wraith | 3 | 02-28-2012 02:08 AM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 266 | 04-01-2011 02:18 PM |
