11-15-2014, 01:04 PM | #1 |
Rock Stacker Join Date: Nov 2013 Location: Meridian, Idaho
| How do I change my wheelbase on my g6
I would like to change the 12" wheelbase on my g6 to 12.3" so I can run the vanquish true 4 link suspension. Is this a common upgrade u fellas do? I notice a lot of slop where the top front link mounts to the front axle. Will I run into issues with my g6? What does it take to do the wheelbase change? Thanks for the help.
11-15-2014, 02:02 PM | #2 |
Newbie Join Date: Sep 2014 Location: ontario
| Re: How do I change my wheelbase on my g6
Hello you purchase the 12.3 links and install them the links length changes the wheelbase.
11-15-2014, 02:03 PM | #3 |
And you need the front truss that should be in your parts bag.
11-15-2014, 10:12 PM | #4 |
Newbie Join Date: Sep 2014 Location: Rolla
Lower links to change wheelbase and upper links to adjust for pinion angle to keep drive shafts from binding especially if you decide to raise the ride height it can become an issue. Do a search on here, if you have some hand tool and measuring skills they are simple to make your own and save some green.
11-16-2014, 10:45 AM | #5 |
just add some washers, spacer, or nuts , place them in front of the rod ends to get the link length you need . no need to buy special links. problem solved
How do I change my wheelbase on my g6 - Similar Threads | ||||
If I change motors do I have to change my ESC? | Coltan | Newbie General | 1 | 04-03-2012 02:04 PM |
Change | hotwheels000 | Losi Mini-Rock Crawler | 2 | 01-07-2012 07:46 PM |
They should change the name of it | menace | Chit Chat | 7 | 08-14-2010 05:08 PM |
