12-16-2014, 02:29 AM | #1 |
Rock Stacker Join Date: Mar 2014 Location: HK
| Why BRXL, how does it comparing with an AE2?
I am running an AE-2 with a 35T motor with 2S. So I have seen a lot of good points about BRXL, just want to know if it is worth to get one. My rig: 7.5lb SCX10 AE-2 (custom made water proof) 10 A CC bec 15KG servo Pit Bull RB 1.9 CI 2 stage foam 2S battery As I got my AE-2 water proof (with sealant just like the BRXL) and I have been running my SCX like submarine without any problem. On the other hand, I only use 70% drag brake so my rig can be decent from a steep slope without locking my wheels so Holmes hold is not a selling point for me. Any comment on AE-2 and BRXL will be appreciated |
12-16-2014, 02:39 AM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Why BRXL, how does it comparing with an AE2?
Why not a Mamba Max Pro? Then you can go sensors brushless when the desire hits.
12-16-2014, 02:43 AM | #3 |
Thanks for your comment, I am not sure how does the sensor-ed system work under water. As I know, only sensor-less brushless works under water, but the low speed control is not smooth enough for crawling
12-16-2014, 03:09 AM | #4 |
I am running a sensored 2800kv MMP in both my 4x4x4 Wraith and my SCX-WRATH. The low end is as good as a brushed.
12-16-2014, 03:22 AM | #5 |
Yes, I know only sensor-ed will run smooth as a brushed. But do you go under water?
12-16-2014, 11:59 PM | #6 |
Quarry Creeper Join Date: Oct 2010 Location: denver
If you waterproofed your ae2 you can waterproof a mmp/sensored brushless setup. Epoxy and dielectric grease. |
12-17-2014, 12:23 AM | #7 |
RCC Addict Join Date: Oct 2012 Location: Norcal
Surprised nobody has mentioned it can take from 2s to 6S!
12-17-2014, 01:20 AM | #8 |
Pebble Pounder Join Date: Jun 2013 Location: Espoo, Finland
If you are happy with your current setup, why upgrade? Do you think about running on 3S (which I think everybody should when using brushed motors in scalers)? I have 4x BRXL, 1x SV3 and 1x WP AE-2 and while driving I really can't tell any difference between them. Except that I can run my Wraith with 4S. All use TRX Titan 21t motors. Edit: FYI, Sv3 runs on 3S no problem, and I've also run my AE-2 with CCBEC using 3S with zero problems. |
12-17-2014, 01:40 AM | #9 |
Quarry Creeper Join Date: Aug 2014 Location: Mission viejo
The ae2 is already a high quality esc aside from the fact that it's unable to run 3s without an external bec. The newer scx10s come with the ae5, which is not as high quality. I ordered a brxl just tonight to replace the ae5 , along with their cheaper crawler motor. For someone in your situation considering you already have an external bec I wouldn't bother with the Holmes esc. I would however look into their motors as I've heard great things Sent from my iPhone using Tapatalk |
12-17-2014, 02:43 AM | #10 |
I wonder how to waterproof a sensored motor. Norton, yup I am aware of that , however I would like to power my rig with 2S |
12-17-2014, 02:47 AM | #11 | |
| Re: Why BRXL, how does it comparing with an AE2? Quote:
Thanks! | |
12-17-2014, 02:50 AM | #12 | |
Haven't thought about their motor yet. It sounds interesting, please let me know about that! | |
Why BRXL, how does it comparing with an AE2? - Similar Threads | ||||
AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position. | Tread Well | Newbie General | 7 | 06-18-2013 02:14 PM |
Comparing the Axial JK to the proline jk?'s | Bananaclip | Paint and Body | 1 | 02-03-2013 09:15 PM |
Comparing a 1gen to 3gen | MilesToEmpty | General Crawlers | 9 | 02-21-2006 03:19 PM |
