01-06-2015, 06:39 PM | #1 |
Newbie Join Date: Dec 2014 Location: Cabot
| Adjusting steering
I am driving slightly right but my adjustment on my controller is all the way to the left so I can't adjust it anymore. What can I do? Thanks |
01-06-2015, 06:41 PM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: Australia
| Adjusting steering
Start over. With the truck and controller turned on, remove the servo horn from the servo. Turn your steering trim back to the centre and then with it all turned on and the trim centred, THEN put the servo horn back on. Be careful when removing the servo horn - if the screw is stuck you will move the servo so be careful here. Sent from my iPad using Tapatalk |
01-06-2015, 06:41 PM | #3 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Adjusting steering
Remove servo arm, center servo, re-install arm. Adjust tie rods
01-20-2020, 06:30 PM | #4 |
Newbie Join Date: Dec 2019 Location: USA
Even after starting over - removing servo horn centering trim to zero then reinstalling servo horn - I still cant get it centered without making trim adjustments. Is this normal? Sent from my SM-N976V using Tapatalk |
01-21-2020, 09:27 PM | #5 |
Rock Crawler Join Date: Apr 2014 Location: Portland
A little bit of trim adjustment is fine.
03-13-2020, 07:46 PM | #6 |
Newbie Join Date: Dec 2019 Location: Columbia
| Re: Adjusting steering |
03-14-2020, 12:00 AM | #7 |
Quarry Creeper Join Date: Jun 2009 Location: Abbotsford BC Canada
Lengthen or shorten the rods by adjusting the ball links after you get your servo horn as close to center as possible..Then you can subtrim to centre. |
Adjusting steering - Similar Threads | ||||
ae-2 adjusting question | DirtyBird33 | Newbie General | 6 | 04-07-2011 12:57 AM |
MRC mixer adjusting?s | zr600 | Losi Mini-Rock Crawler | 4 | 04-10-2010 06:17 PM |
adjusting drivetrain | towjockeyrc10 | Axial SCX-10 | 2 | 10-10-2009 06:48 PM |
Adjusting shocks?? | jkwrangler08 | Losi Mini-Rock Crawler | 2 | 08-06-2009 05:08 PM |
