06-11-2015, 05:48 PM | #1 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
| Trailing arm, slightly custom build
So I crashed my scx10 pretty hard last weekend. Decided to go a different route with my repairs. I broke a vp link, not the rod end. So I decided to go to a trailing arm setup, with Werty arms. I also wrecked the frame, so, in a hard decision, I went with the TSS scxhr chassis in alu. The arms and frame should be in next week. Since 3 of 4 shocks are done, I am going to mock up the chassis prior to ordering new shocks, thanks to Eric0424 for the recommendations on associated shocks. Once I get the frame rails, I will start the teardown/rebuild, for now I have borrowed the wheels and tires for the Steg6 this weekend. Also will be 'borrowing' the servo, which is a holmes. Pics to come
06-11-2015, 06:30 PM | #2 | |
| Re: Trailing arm, slightly custom build Quote:
Your pics show as links that won't open for me. | |
06-11-2015, 06:42 PM | #3 |
| Re: Trailing arm, slightly custom build My rig thought it could fly....off a cliff |
06-12-2015, 12:52 AM | #4 |
meh... it'll hammer out |
06-12-2015, 08:56 AM | #5 |
Pebble Pounder Join Date: Jun 2006 Location: newark
you just wanted an excuse to make a tuber out of it lol
06-12-2015, 08:58 AM | #6 |
| Re: Trailing arm, slightly custom build |
06-12-2015, 09:07 AM | #7 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
06-19-2015, 08:32 PM | #8 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
06-22-2015, 08:10 PM | #9 |
OK, I have the chassis, it came in the mail today. When I get home from work that's getting done tonight. There's also a chance that my trailing arms are at home, but possibly tomorrow.
06-23-2015, 10:55 AM | #10 |
| Re: Trailing arm, slightly custom build I pulled this stuff this morning. Tss frame and werty ta are bolted in, but need some link adjustments |
06-24-2015, 09:32 AM | #11 |
| Re: Trailing arm, slightly custom build Doing some test fitting, I need shorter front uppers, my angles are whack. I think I can get away with 90mm shocks on the ta. My big fit problem right now is this, so I've contacted werty and he's helping me out with a new bumper to help clear this. |
06-24-2015, 09:39 AM | #12 |
06-24-2015, 10:01 AM | #13 | ||
x2 Quote:
That looks good so far and the body too! | ||
06-24-2015, 10:09 AM | #14 |
| Re: Trailing arm, slightly custom build Ya this body has had some love already, but I guess I forgot a reference pic eh. I'm not going for huge aesthetic changes here, I'm pretty happy with where it is right now. The front bumper though, I'll be glad to see gone. It was an rc4wd 'tough armor', but I broke the d ring shackle off on the second run. And the too winch plate is warped. I don't know why they call it tough. |
06-24-2015, 10:12 AM | #15 | |
I'd cut off front bumper on body before you get you new bumper built. | |
06-24-2015, 10:18 AM | #16 |
| Re: Trailing arm, slightly custom build I already cut off 95% of the front bodyshell bumper. I kept the lip, for a bit of stiffness. Ya 1.9treps 4.50 lil nova softs on ci 2.2 1 in wide. Running a 350 hub vp slw I had sitting there. With traxxas wide hexs, it fits the VP 8deg fronts.
06-27-2015, 01:05 PM | #17 |
| Re: Trailing arm, slightly custom build Mocked up using stock scx10 shocks on the rear, salvaged pl scalers on the front. It looks like I can buy a new set of scalers for the rear, as this length shock gives a pretty decent stance and a lot of wheel travel |
06-30-2015, 10:35 PM | #18 |
Newbie Join Date: May 2015 Location: valparaiso
love the wertymade trailing arms hows the flex compaired to stock with them on your scx10. And holy carnage : )
07-05-2015, 08:58 PM | #19 |
Small update: have some custom front upper links coming to fix my pinion problem. The front uppers I had on, went to the rear uppers, pinion angle is right where I want it now. Have my werty bumper, have only mocked it up, but fits perfect. The dcw honcho hinges fit the frame perfect, I had them on the old frame, and they survived. Have a stack of parts coming, including od/ud gears and some pitbulls. Some axial 8 holes, which I'm thinking need a color change. |
08-02-2015, 08:02 PM | #20 |
Have almost completed the build, still require 2 screws to finish. 2 screws. Will have pictures up tomorrow of the completed, minus 2 friggin screws, build. Sent from my Nexus 5 using Tapatalk |
Trailing arm, slightly custom build - Similar Threads | ||||
My Blue Monkey IFS/Trailing Arm Wraith Semi Build Thread | BuzzinHornets | Axial Wraith | 24 | 05-07-2014 10:48 AM |
Trailing Arm Suspension for a trailer | neillarson | General Scale Talk | 11 | 07-03-2011 09:15 PM |
Shortcourse 4-link vs. trailing arm | desertmaxx | Non Crawler RC's | 4 | 09-07-2010 06:40 PM |
trailing arm links | mookie | Redcat Crawlers | 6 | 07-07-2010 06:43 PM |
