Thread: I have a clearance problem, solution?
Old 06-11-2015, 09:24 PM   #1
Default I have a clearance problem, solution?
So its an SCX10, that Im building to have a ~10" wheelbase. It has a DIG on the trans, its supposed to be on the rear shaft but I run it on the front, for scale realism. The rear shaft (Metal, dont know the brand) is contacting the spur gear, and the cross pin jams it right up. What is the best solution, smaller spur or going back to a plastic driveshaft?
(Heres a crappy picture)
epic_username is offline   Reply With Quote
Old 06-11-2015, 09:37 PM   #2
Default Re: I have a clearance problem, solution?
Drop the spur a tooth or two or check out Holmes Hobbies for their extended tranny outputs.
travis c. is offline   Reply With Quote
Old 06-11-2015, 10:05 PM   #3
I joined the Band!
Smaller spur and pinion if you want to keep the current gearing. Output extension will work too, but may limit your articulation (driveshaft bind) depending on how much travel you want.
Eric0424 is offline   Reply With Quote
Old 06-11-2015, 10:51 PM   #4
I think since its already got a pretty short wheelbase an output extension wouldnt work, although Ill keep them in mind, I didnt know they existed :P Ill have to grab a smaller spur :P Thanks!!
Old 06-12-2015, 02:06 AM   #5
You could also use dual motor plate and move the motor to upper position, but it will move your CG as well ...
zach23 is offline   Reply With Quote
Old 06-12-2015, 08:41 AM   #6
try a junfac drive shaft alot smaller but still metal and built well
fullsizecrawler is offline   Reply With Quote
Old 06-13-2015, 10:03 PM   #7
+1 for Junfac Carbon Steels. Or of course the ever-revered MIPs
QYKSLVR is offline   Reply With Quote
Old 06-13-2015, 10:06 PM   #8
that is for sure a mip shaft. Junfac use metal rings to hold the pin in.
fr8cture is offline   Reply With Quote
Old 06-13-2015, 10:19 PM   #9
If you pick up an extended wraith MIP drive hub, part#MIP11117. It will easily clear a 60t, possibly a 62 with lathing (or grinding in my case) the hub thinner..............I might have to try this, I have a rig that could be geared down a bit.
I have a clearance problem, solution? - Similar Threads
a little motor clearance problem crazy nick Axial SCX-10 4 12-11-2013 07:59 AM
Bearing problem...looking for solution biggin69 Axial XR10 9 09-25-2011 05:38 PM
Rear axle "clicking" problem/solution. GRIMGREG Axial AX-10 Scorpion 1 07-04-2011 02:27 PM
BIG problem, SIMPLE solution Erik D_lux Team Losi Comp Crawler 27 10-08-2010 03:10 PM
