06-12-2015, 02:28 PM | #1 |
Pebble Pounder Join Date: Sep 2014 Location: las vegas
| My "Hybrid" chassis build This is a chassis was designed by Issued LV Scalers, I did the CAD work for it. I will post up more pic soon. Sent from my SM-G900V using Tapatalk |
06-16-2015, 08:25 PM | #2 |
| Re: My "Hybrid" chassis build
This is a new aluminum frame, I upgraded to Titanium links, this chassis has the ability to relocate the front and rear upper links. This chassis is meant to take 100mm shocks, with the high shock mounts it allows the shock to use all of its potential without the axle hitting the shock mounts Sent from my SM-G900V using Tapatalk Last edited by fshnut007; 06-17-2015 at 09:21 PM. |
06-16-2015, 08:31 PM | #3 |
The rear bumper is Pig Snot Chassis, front bumper is RC4WD, and the rock sliders are Scaler Fab. The beadlock rings are ours Desert Scalers. I run a Hitec hs-7954sh servo on a bec cause I run 3s lipos in it. I run 14/87 gearing in it. When I'm done with the body I will post pics. Sent from my SM-G900V using Tapatalk |
08-10-2015, 10:25 PM | #4 |
I finally finished it, I modified a XJ body with interior kit, a custom aluminum rear cage, Vanquish light bar, and a homemade snorkle. Sent from my SM-G900V using Tapatalk Last edited by fshnut007; 09-03-2015 at 04:16 PM. |
08-11-2015, 07:31 AM | #5 |
Pebble Pounder Join Date: Aug 2011 Location: gaylord
Nice looking rig, but that is a xj.
08-11-2015, 07:33 AM | #6 |
Thanks, yes it's an XJ with the back cut off. Sent from my SM-G900V using Tapatalk |
08-11-2015, 04:27 PM | #7 |
...very nice like the frame... fab that yourself ? |
08-11-2015, 04:30 PM | #8 |
No, actually the guy who designed the chassis built the cage. Sent from my SM-G900V using Tapatalk |
08-11-2015, 05:20 PM | #9 |
So I forgot to mention the mastermind behind the chassis is Matt Wolfe which is LV Issued Scalers, also I ended up shortening the 100mm shocks to 90mm, wanted it a little lower. Here is another perspective of the rig. Sent from my SM-G900V using Tapatalk |
09-03-2015, 04:06 PM | #10 |
| Re: My "Hybrid" chassis build I just realized I wrote the wrong jeep model, I was agreeing with you on the model on your comment, not knowing I accidentally wrote the wrong jeep model. Fixed now. Sent from my SM-G900V using Tapatalk Last edited by fshnut007; 09-03-2015 at 04:17 PM. |
09-29-2015, 02:44 PM | #11 |
I made these brackets to keep the body mounts from moving which causes the screw to loosen, I also up sized the mounting screw to a 6-32 with red loctite to give it more bite in the body post mount. It's solid now. Sent from my SM-G900V using Tapatalk |
01-07-2016, 06:35 AM | #12 |
Here's some revised pics of my xj with my Wertymade front and rear bumper. Sent from my SM-G900V using Tapatalk |
My "Hybrid" chassis build - Similar Threads | ||||
First of its kind,"Top Secret BatMan" hybrid Wraith chassis with AX10 axles | Mighty1 | 2.2 Scale Rigs | 29 | 12-30-2013 11:22 AM |
Harley's Axial Comp Chassis - "Hybrid" | Harley | Chassis and Suspension | 43 | 11-06-2008 08:33 PM |
Project "TimberWolf" 1.9" Scale Yota Hybrid | 51WillysJeep | 1.9 Scale Rigs | 53 | 08-14-2008 06:43 PM |
