Thread: Rub trouble :)
Old 06-28-2015, 11:44 PM   #1
Default Rub trouble :)
I'm running pitbull rock beasts on steelies, w. The vp 8 degree knuckles and chubs. I put in the traxxas spacer and I'm still rubbing. Any ideas other than vp wheels?
Thanks!
visceral is offline   Reply With Quote
Old 06-29-2015, 12:22 AM   #2
Norton's Avatar
Default Re: Rub trouble :)
Junfac Wheel Widener (Offset: +13mm)
Norton is offline   Reply With Quote
Old 06-29-2015, 10:06 AM   #3
Cool Thx. Won't this require the axle ends to be longer? I'm already low on threads for the nut.
Old 06-29-2015, 11:06 AM   #4
I joined the Band!
The Junfac widener kit is supplied with barrel nuts, lock washers and flat washers, you use them instead of the M4 nylon lock-nut.
Eric0424 is offline   Reply With Quote
Old 07-01-2015, 06:13 PM   #5
So it somehow pushes out the inner part of the tire, without needing more threads on the axles? I'm probably not getting something here. Thx for the help.
Old 07-01-2015, 07:07 PM   #6
I joined the Band!
The barrel nuts (silver bolts in the picture below) reach deeper into the 12mm widener hub to grab the threads on the axle.
Old 07-02-2015, 09:54 AM   #7
Natedog's Avatar
Thanks!
Originally Posted by Norton View Post
Or you can buy different hubs to widen the track, or run Axial aluminum high steer knuckles because they don't rub the tires like VP does.
Rub trouble :) - Similar Threads
Will my PB RB's rub? Jeep757 Tires and Wheels 11 05-30-2014 07:37 PM
Tire Rub. Help juttsvw RC4WD Trail Finder 2 22 05-03-2013 04:39 PM
Possible rub Issue? BrianP Losi Mini-Rock Crawler 0 11-05-2011 12:10 PM
AX-10 and the tires rub asw27x Axial AX-10 Scorpion 6 05-31-2010 12:20 AM
rub wanttocrawl Newbie General 4 08-13-2008 04:21 AM
