07-20-2015, 03:10 PM | #21 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
| Re: My Burly truck build
Well that was mock up, the truck has been disassembled! Now I will start a final assembly. I did get some high quality China made aluminum parts. They do work well for the price. Sent from my iPhone using Tapatalk |
07-20-2015, 03:11 PM | #22 |
I did paint the Burly kit to match the frame rails. Sent from my iPhone using Tapatalk |
07-20-2015, 06:35 PM | #23 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
Watching.
07-20-2015, 06:36 PM | #24 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Re: My Burly truck build |
07-20-2015, 07:28 PM | #25 |
07-20-2015, 07:37 PM | #26 |
I completed the front axle. Parts are as follows, VP cvd's VP Locker Home made brass axle tubes GPM c-hubs GPM knuckles RC4WD 12mm wideners Axial HD Underdrive gears STRC axle truss Hi-Tech 7954 servo I didn't like that the strc axle truss didn't have a third point of attachment. So I shortened the servo plate then drilled through the plat into the truss. Counter sunk the hole then tapped the hole. Sent from my iPhone using Tapatalk Last edited by mudbeast2; 07-21-2015 at 05:05 AM. |
07-20-2015, 07:41 PM | #27 |
Newbie Join Date: Feb 2015 Location: Cedar Run
Nice job on the axle tubes. May have to borrow. Looking killer. That color on the aluminum parts is gonna look great with your body. Sharp as hell. WD before you go in. Used to use Pam cooking spray on the dirtbikes. it'll look good clean or dirty. Last edited by THX_138; 09-19-2015 at 10:25 PM. |
07-20-2015, 07:42 PM | #28 |
Thank you, it may be to pretty to mud! Lol Sent from my iPhone using Tapatalk |
07-20-2015, 08:09 PM | #29 | |
| My Burly truck build Quote:
Good advise! Last little bit of bling installed for tonight. I installed the GPM aluminum gear case & VP motor mount & gear guard. Sent from my iPhone using Tapatalk Last edited by mudbeast2; 07-21-2015 at 05:05 AM. | |
07-21-2015, 06:45 AM | #30 |
I had a little extra time this morning so I installed the shock mounts. Sent from my iPhone using Tapatalk |
07-22-2015, 05:43 AM | #31 |
I made progress last night, I completed the rear axle with the homemade brass axle tubes and reassembled the truck. I still do not have a fantastic power plant yet but we will see what I can come up with. I then shortened my battery plate and added a piece of Kydex to the front chassis so that my electronics box and speed controller will be lower down on the frame. Sent from my iPhone using Tapatalk |
07-22-2015, 08:28 AM | #32 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
great progress! china parts ftw!
07-22-2015, 10:50 AM | #33 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I'm running the Castle 3800/Sidewinder on 2S in mine atm...flings great but since the rig is still able to crawl, sensorless is a PITA at times. Maybe something lower Kv and higher voltage for more efficiency, or the HH sensored + WP combo.
07-22-2015, 11:20 AM | #34 |
Being that this rig is strictly a mud basher, I was thinking about the Traxxas VXL-3s. It's a 3500 kv motor & its waterproof. Sent from my iPhone using Tapatalk |
07-22-2015, 02:26 PM | #35 |
That would work. For some reason I thought you have Mud Bashers but I guess it's because that guy posted the pic. Run it on 3S for extra damage |
07-22-2015, 02:29 PM | #36 |
The mud Bashers just came today & I do run 3s. Sent from my iPhone using Tapatalk |
07-22-2015, 02:37 PM | #37 |
| Re: My Burly truck build Mud Bashers & beadlocks showed up today. Sent from my iPhone using Tapatalk |
07-22-2015, 03:47 PM | #38 |
Cool, I just saw the post now from the 19th. I know I had a big smile on my face after the first throttle pull in mud with the Slingers.
07-22-2015, 05:08 PM | #39 |
I'm still waiting for my closed cell foams from C.I. But I had to see the Bashers on her. They look sick! But I may have to push the rear axle back a little to center the axle with the body. The wheel base is at 13" now it may have to be at 13.25-13.5" when done. Sent from my iPhone using Tapatalk |
07-22-2015, 06:51 PM | #40 |
Killer looking rig.The color and wheel/tire combo just all works. Maybe a tad stretch on the rear.Trim them wheel wells a tad also.
My Burly truck build - Similar Threads | ||||
Burly Mud Truck Conversion | RcBro | Chassis and Suspension | 25 | 07-05-2018 07:46 PM |
Harley's Ram Power Wagon Burly Mud Truck | Harley | Axial SCX-10 | 30 | 11-19-2015 03:28 PM |
** RCBROS Burly Mud Truck Giveaway ** | RcBro | Axial SCX-10 | 328 | 07-14-2015 03:41 PM |
