07-12-2015, 06:02 AM | #1 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
| My Burly truck build
Since I first seen Harley's post on this subject I had to build one. I did use several of his recommendations. This truck does not disappoint! So here are the pictures. This is the donor truck. The parts that will be used. I did install under drive gears front & rear. I also installed RC4WD 12mm wheel spacers to stop the 2.2 tires from rubbing. I used 110mm king shocks with 50 wt in the rear & 40 wt in front. I also installed Gear Head shock keys to help compensate for the burly kit. Everything is bolted up & fits great. I used this Proline Chevy body due to it having a 13.25" wheel base. I got the body painted, this turned out awesome! Best paint job I ever did. Sent from my iPhone using Tapatalk Last edited by mudbeast2; 07-12-2015 at 06:04 AM. |
07-12-2015, 06:11 AM | #2 |
| Re: My Burly truck build
The power train consists of a AE-5 ESC, 20 turn Wraith motor, 16 tooth pinion, 87 tooth spur, steel gears in trans & RR one piece bottom gear. Drive shafts are MIP AX10 shafts with Super Shafty exclusive splines. These are a must with the longer wheel base. This rig is running on 3s. I ran this rig for 20 minutes in tall grass and the temps didn't exceed 105 degrees. Sent from my iPhone using Tapatalk |
07-12-2015, 06:26 AM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
That looks fantastic.Great choice on the body colors.
07-12-2015, 08:31 AM | #4 |
Here are a couple more pics. The rig definitely needs sway bars! I have to see what Harley came up with. Lol Comparison pic, Burley truck to stock scx10 Sent from my iPhone using Tapatalk |
07-12-2015, 09:48 AM | #5 |
Newbie Join Date: Sep 2010 Location: westpalm
Great paint on that burly rig! Are you sure that's a stock scx10? Lol!!!!!
07-12-2015, 02:56 PM | #6 |
It is a beast! Thanks buddy! Sent from my iPhone using Tapatalk |
07-12-2015, 07:23 PM | #7 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
Some great ideas here for my rig! Nice build!!!
07-15-2015, 04:03 AM | #8 |
Took the burly truck out for her first mud run. She did very well but needs some tuning. Sent from my iPhone using Tapatalk |
07-15-2015, 08:41 AM | #9 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
jeeeeez this man wasted no time running out to the mud hole! nice shots! nice truck! |
07-15-2015, 08:43 AM | #10 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Sweet video What motor are you using again? |
07-15-2015, 08:59 AM | #11 |
Shame to muddy it up but I guess that's what you built it for.That slow motion mud flinging looked fantastic.Almost sounded like gear grindage at the end.
07-15-2015, 10:09 AM | #12 |
| Re: My Burly truck build |
07-15-2015, 11:23 AM | #13 |
Newbie Join Date: Feb 2015 Location: Morgantown
Ya the paint looks great is there tons of body roll that's I wanted to no before I get a set
07-15-2015, 08:01 PM | #14 | |
| Re: My Burly truck build Quote:
Thanks, there is body roll but I was able to control it with stiffing the shocks on one side of the Vechicle. But I think it definitely needs sway bars at least in the rear to start. Sent from my iPhone using Tapatalk | |
07-15-2015, 08:09 PM | #15 |
I received my Super Shafty executive MIP's today. I only needed it for the rear. They are solid and work well. Here's the rear And the front Sent from my iPhone using Tapatalk |
07-18-2015, 12:21 AM | #16 |
Rock Stacker Join Date: Jul 2015 Location: Terry
07-19-2015, 06:15 AM | #17 |
07-19-2015, 04:40 PM | #18 |
Did some trail riding today, here is the burly truck flexing out! Sent from my iPhone using Tapatalk |
07-20-2015, 12:46 AM | #19 | |
Rock Stacker Join Date: Jun 2015 Location: K
Sent from my XT1080 using Tapatalk | |
07-20-2015, 03:11 AM | #20 |
The slipper is locked down. The tires do rub a little. Sent from my iPad using Tapatalk |
My Burly truck build - Similar Threads | ||||
Burly Mud Truck Conversion | RcBro | Chassis and Suspension | 25 | 07-05-2018 07:46 PM |
Harley's Ram Power Wagon Burly Mud Truck | Harley | Axial SCX-10 | 30 | 11-19-2015 03:28 PM |
** RCBROS Burly Mud Truck Giveaway ** | RcBro | Axial SCX-10 | 328 | 07-14-2015 03:41 PM |
