08-06-2015, 06:45 AM | #61 |
Rock Stacker Join Date: Jun 2009 Location: charleston
| Re: My Burly truck build
OK thanks!!!
08-11-2015, 06:01 PM | #62 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
Sorry it's took so long to get back to you, work has been crazy. The front lower links are 6 1/8 of an inch center to center the rear lower links are 7 inches center to center. Sent from my iPhone using Tapatalk Last edited by mudbeast2; 08-11-2015 at 06:14 PM. |
08-11-2015, 06:02 PM | #63 |
The missing link has arrived finally! thank you Amazon for taking so long. I will start installation this evening. Sent from my iPhone using Tapatalk |
08-13-2015, 04:21 PM | #64 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: My Burly truck build |
08-18-2015, 07:39 PM | #65 |
Ok, the brushless system is installed & tested. Lots of power on 3S. I also put a heat sink on the motor to help keep it cool. I haven't tested it out yet. But the mud pit is coming. I'm going to build a 4' x25' mud drag pit on the side of my house this weekend. It will be wide enough to run 2 rigs at the same time. It will have a ramp to jump into the pit then a wood ramp to get out. I will frame it with 1x6. The pit will be lined with plastic to keep water in. The mud will be about 4" deep. Sent from my iPhone using Tapatalk |
08-18-2015, 07:41 PM | #66 |
I can't wait to run her in the mud pit at RRW during the G6 in October! This rig is a beast! Sent from my iPhone using Tapatalk |
08-18-2015, 07:51 PM | #67 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
Love this truck.Should preform well in its element.Nice job.
08-18-2015, 09:49 PM | #68 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Will that sway bar help?
08-19-2015, 03:46 AM | #69 |
The sway bar made a huge difference! Helps under acceleration and when turning. Sent from my iPhone using Tapatalk |
08-24-2015, 10:31 PM | #70 |
Did you get the MUD PIT done?
08-25-2015, 07:06 AM | #71 |
Quarry Creeper Join Date: Jun 2008 Location: San Antonio
looks sweet bro! The paint on that body is awesome! Whole rig looks great! |
08-25-2015, 07:16 AM | #72 |
08-26-2015, 04:47 PM | #73 |
Pebble Pounder Join Date: Jul 2015 Location: Fort Collins
How did those wheels work with the thicker beads on the tires? My wheels kept cutting the bead off my tires when I was running the RB2's
08-26-2015, 04:49 PM | #74 | |
| Re: My Burly truck build Quote:
The wheels really work well. The beads lock in nice. I haven't had any problems at all. This is the second set I've owned. Sent from my iPhone using Tapatalk | |
09-03-2015, 11:05 PM | #75 |
Any up dates?
09-07-2015, 01:31 PM | #76 |
Yes there are a couple. With all the brushless power I keep killing the hd gears. I have a set of ssd axle housings on the way. I am going to install one housing in the rear to see if it will hold up to the power. I also built a trailer to haul her to the G6 in October.
09-07-2015, 01:33 PM | #77 |
| Re: My Burly truck build Sent from my iPhone using Tapatalk |
09-10-2015, 03:47 AM | #78 |
I installed SSD axle housings, hoping they will hold up to brushless 3s power. Sent from my iPhone using Tapatalk |
03-30-2016, 02:56 PM | #79 |
Newbie Join Date: Apr 2009 Location: deltona
what are he heels and tires on the truck? the tractor style ones. and what non aluminum wheels will fit them?
03-30-2016, 10:08 PM | #80 |
My Burly truck build - Similar Threads | ||||
Burly Mud Truck Conversion | RcBro | Chassis and Suspension | 25 | 07-05-2018 07:46 PM |
Harley's Ram Power Wagon Burly Mud Truck | Harley | Axial SCX-10 | 30 | 11-19-2015 03:28 PM |
** RCBROS Burly Mud Truck Giveaway ** | RcBro | Axial SCX-10 | 328 | 07-14-2015 03:41 PM |
