08-21-2015, 03:02 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| Pinion spur gearing 32p
Anyone who has changed to 32p spur and pinion what tooth count and motor combo are you utilizing?
08-21-2015, 05:59 PM | #2 |
| Re: Pinion spur gearing 32p
56/12 with a Holmes Crawlmaster 13t and 5.5 inch tall tires is a tiny bit faster than a fast walk. This is on 2s. With this combo and an axial 20t the speed doubles.
Last edited by SCREAMER; 08-22-2015 at 09:57 AM. Reason: Forgot to mention tire size |
08-21-2015, 06:08 PM | #3 |
Ok my sons 48p are getting worn from the sand and river silt and i have a 32p 54t spur and a 9t pinion laying around hes running a 16t crawlmaster whats the opinion of this combo?
08-21-2015, 06:48 PM | #4 |
Rock Crawler Join Date: Apr 2009 Location: bend
56/10 with a 35t motor on my wroncho.... I am also running 5.75 IROKS.
08-21-2015, 09:22 PM | #5 |
| Re: Pinion spur gearing 32p That doesn't sound too crazy. I don't know what gearing ratio you were running before but 54 spur and 9 pinion are about the smallest sizes I've heard of for both, on an SCX anyway. I would just give it a try and be ready to buy some bigger pinions for dialing in the wheel speed. Pinions are cheaper and easier to change. I have an assortment that I've built up for just this reason. Keep an eye on your motor temps too after the switch. HTH
08-21-2015, 10:08 PM | #6 |
We tried it out tonight he ran the truck for about an hour a bit faster than the 48p 87/14 gearing still climbs well the motor didnt get overly warm ( could easily hold my fingers on it for extended periods he is running larger tires as well (axial 1.9 bf krawlers) might see if i can source a slightly larger spur and experiment a bit.
08-21-2015, 10:59 PM | #7 |
With my daughters wraith I used 87/12 and it's been about 4 yrs on the stock motor.
08-21-2015, 11:12 PM | #8 |
Im sure the 48p will work well for most people but here we have an abundance of silica (sandblasting sand) and fine silt as we reside in an area comprised of river valleys so it gets in through screw holes with the water needless to say teardowns and greasing/cleaning are quite ritual events
08-22-2015, 07:57 AM | #9 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Running 56/11 on my SCX with 4.19 Claws and a 35t
08-22-2015, 08:50 AM | #10 |
| Re: Pinion spur gearing 32p |
08-23-2015, 11:28 AM | #11 |
Rock Stacker Join Date: Jul 2014 Location: Hollis
56/9 with an Atomic 35t and 2s. Crawls nice. Stock Trepador tires
Pinion spur gearing 32p - Similar Threads | ||||
32P pinion/spur choice | desertdude | Axial SCX-10 | 22 | 06-09-2015 07:26 PM |
32p spur/pinion conversion | shakemandril | Vaterra Twin Hammers | 6 | 12-25-2013 01:08 AM |
32p spur/pinion questions | tbilz | Formula Offroad | 16 | 05-30-2011 07:13 AM |
Anyone run 32P Pinion/Spur Gears? | MDcrawler72 | Axial SCX-10 | 18 | 05-15-2010 09:38 PM |
