10-23-2015, 09:03 AM | #1 |
Pebble Pounder Join Date: Aug 2010 Location: claremont... for now
| slow build of a honcho china jk
so i started out with a honcho that a friend bought that was very neglected, had all the makings for a great long slow build. i wanted to build the ultimate scale truck, and mcrawlinslow added to that with his build (my 2dr china jk with little VP treatment!) so heres what I'm starting with[IMG][/IMG] now i ordered the body from asiatees, and while it was a bit pricey due to them being over seas, i am amazed it got here in literally 3days!!! quality is amazing... i ordered a dual servo mount and front motor/trans mount from gcm, that should hopefully get here in a couple days as well. so wheelbase for the honcho is around 12 1/4" and I'm going to make my own rear links for now to see if i can get it down to around 11 1/4" guess thats all for now. will update when i can! thanks for looking |
10-23-2015, 06:37 PM | #2 |
Pebble Pounder Join Date: Jan 2015 Location: South Central PA
| Re: slow build of a honcho china jk
I've been thinking about doing the same thing with my honcho but seems like a lot of work to modify the chassis enough to make this body fit. Will be watching this closely. Keep the updates coming.
10-25-2015, 12:52 PM | #3 | |
| Re: slow build of a honcho china jk Quote:
and the wife yells when i spend 2much time and money on things other then her lol it dont seem like alot of work, i will be working on links once my GCM parts gets here. might have to cut like a 1/2" off the back of the frame but it again once i get all the links done thatll get done! wish i could bring my tools and all this stuff to work, but apparently babysitting drug dealers and murders is more important then getting my things done lol | |
10-28-2015, 04:01 PM | #4 |
some goodies are starting to come in got the dual servo mount all bolted up got my motor and trans bolted up to the plate looks like i gotta take the dremel to a couple spots where it hits gotta get a new dremel, apparently mine burnt up when i lent it to a friend, so that will be fridays purchase and here is the 4 link mount for the rear, all products are from GCM racing, shipping was fast and quality seems great so far!! more progress when parts start rolling in! |
11-03-2015, 01:12 PM | #5 |
so got a lil bit more work done on it yesterday and 2day. got myself another dremel so got this trimmed so the motor/trans can sit down where it needs to also got some more things in got the hardened gears and holmes hobbie crawlmaster locker in front 3 link and panhard bar getting installed just gotta finish the rear upper links for the 4 link and button up a couple things and then it should be time to start getting the body mounted and running the electronics etc... also still waiting for the gcm transfer case that should be here this week, might also order front and rear vanquish axles cus im pretty sure the stock ones have a bit of a bend in them... we shall see how the ot is for the next couple days. Last edited by ny98banshee482; 11-03-2015 at 01:51 PM. |
11-16-2015, 04:39 PM | #6 |
finished up the mock up of the rear links got the transfer case mocked up as well, idk how i feel about it, i will clean that plate up if i plan on keeping it need to get the RC4WD punisher shafts for the rear and the shaft that goes from the transfer case to the tranns, since the mips are to long got the bumpers mounted, need to start trimming the body soon im pretty sure i figured out where im going to run all the electronics, but i have to find some nice rock sliders for that, still lots to do, but i will be holding off till after the holidays, damn ot and xmas spending puts a hold on my hobby $, still havent figured out how im going to mount the body to the chassis, ive seen a couple different ideas that i will try, this is my first ever hard body and im soooo afraid to start hacking it up haa but on 1 of my days off that will be the next thing... still to come, wheels and tires and lots of scale goodies, winch and paint! id also like to add a cowl hood with some styrene so ill be trying my hand at that eventually something like this hopefully |
01-07-2016, 09:06 PM | #7 |
ok so its been awhile since i posted, not really a whole lot done, between the holidays, working 3rd shift with massive amounts of ot every day, and waiting for parts to come in, but heres what i did, so i got 90mm shocks for the front but with all the weight of the gcm they were very unresponsive and would pretty much not rebound back so i ordered a spring kit and put much heavier duty springs up front, and then in the rear, i put softer 90mm springs in the 80mm shock and that gave it a nice feel. finally got in my custom made scalerfab rock sliders, they are beautiful! also got my wheels and tires all mounted up. and i did alot of body trimming and such in some of the pics you will see what i did to mount the body, up front i glued stock axial body post that i cut down. they will mount straight to the stock hoops like normal except i will body clip them in from the bottom and the rear is kinda tough to explain but i think ull get it when u see the pic ok enough talk on to the pics rear body pins sit inbetween the frame rails and will get bolted through here is the front, dont mind the mess of jb weld, that will be sanded and cleaned up b4 paint got the correct drive shafts lengths in there and it looks pretty good theres the body on it, i like the way it sits, well thats all for now, next is to figure out how to mount all the electronics where i think i want them lol, should be fun! |
slow build of a honcho china jk - Similar Threads | ||||
My China made JK Build | TriggerMan | 1.9 Scale Rigs | 52 | 12-08-2016 07:25 AM |
A'nudder China JK build | tokdl | Axial SCX-10 | 49 | 04-28-2016 12:16 PM |
The Blacksheep's Honcho build (slow and steady) | The-Blacksheep | Axial SCX-10 | 9 | 01-18-2012 04:53 PM |
671 slow honcho build | 671_oners | Axial SCX-10 | 2 | 01-11-2012 03:27 PM |
