11-29-2015, 03:01 AM | #1 |
Newbie Join Date: Nov 2015 Location: US
| play in rear scx10 axle?
Hello another dumb random fire question, but I noticed my scx10's rear axle has some side to side play in it. Is this normal? Any way to reduce this? Thanks!! |
11-29-2015, 03:22 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: play in rear scx10 axle?
More information please. If you're talking about turning one tire and the other. You need a spool from hh to help with slop
11-29-2015, 06:35 AM | #3 |
Newbie Join Date: Dec 2013 Location: Kent
It could also be worn rod ends on the links. Mine has this issue right now.
11-29-2015, 01:58 PM | #4 |
I have play in the wheels themselves too, but what I'm talking about is the entire rear axle housing wiggles a little side to side, almost like its the links or something
11-29-2015, 05:16 PM | #5 |
| Re: play in rear scx10 axle? |
11-30-2015, 02:06 AM | #6 |
Ok is this normal for the stock plastic 4 link?
11-30-2015, 08:34 AM | #7 |
Newbie Join Date: Sep 2015 Location: Nashua
I had the same issue. I replaced my plastic links with DIY metal links and it reduced the play significantly.
11-30-2015, 09:42 AM | #8 |
I joined the Band! Join Date: Dec 2014 Location: Earth
11-30-2015, 10:48 AM | #9 |
Quarry Creeper Join Date: May 2009 Location: India
Plastic rod ends have to snap fit on to the pivot balls, hence they are manufactured with adequate tolerance otherwise it would be hard to interlock them. Apart from this , soft plastic is used for rod ends that flexes without a lot of force. It helps manufacturers, but the product life suffers. Metal rod ends are composed of more than the pivot ball and rod end. There are locking rings which lock the pivot ball inside the cup. These are set on a mechanical press insted of snap fit. |
play in rear scx10 axle? - Similar Threads | ||||
End play in rear axle | Motorider | Axial Yeti XL | 2 | 07-07-2015 10:10 AM |
rear axle play | ncampos976 | EnRoute Berg | 4 | 06-23-2013 02:57 PM |
Rear axle play? | (Greg) | Axial XR10 | 10 | 03-27-2011 03:49 PM |
Rear axle upper 3-link play (worn) | Avalanche | Axial AX-10 Scorpion | 10 | 01-14-2009 10:43 AM |
Slight play in rear axle | procraft98 | Newbie General | 10 | 09-20-2007 08:19 PM |
