06-06-2016, 07:57 PM | #1 |
Newbie Join Date: Aug 2015 Location: Vestal
| Spur gear advice
Guys I built a G6 kit...got myself a nice HH crawlmaster 13t so I wanted to change over to 32p gears for durability. I ordered up AX31027 Bore on it is too big. I dont have the dual slipper set up. I need a 56T 32p delrin spur that fits AX30411 Outer Slipper Plate.. Where can I find one...I've been looking and just cant seem to locate one...if somebody could link it would lower my stress level considerably.. Cheers |
06-06-2016, 08:00 PM | #2 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: Spur gear advice
Here is a steel one I'm using my my TTC.. TowerHobbies.com | Robinson Racing Stl Spur 32P 58T Blackened AX10/Wraith Its 58t tho Bolts right onto that single slipper EDIT: Found a 56t http://www.ebay.com/itm/Hot-Racing-S...-/361366508814 Last edited by Capwn; 06-06-2016 at 08:05 PM. |
06-06-2016, 08:46 PM | #3 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
This one bolts right up to the old slipper. http://www.amazon.com/Duratrax-Nitro...ilpage_o05_s00 I'm running big power with the slipper locked up tight and it's holding up great. |
06-06-2016, 08:57 PM | #4 |
Thanks I thought I read somewhere that it would, just wanted to confirm..thanks so much for the info, just ordered two...always good to have a spare.
06-07-2016, 12:03 AM | #5 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Spur gear advice Good call on the plastic spur and a spare. I finally blew one our after almost a year on a HH Puller Pro on 3s. I hate to think about what I might have destroyed if the spur hadn't given out.
Spur gear advice - Similar Threads | ||||
Pinion/Spur advice | Chris G | Axial Yeti XL | 2 | 06-21-2015 05:58 AM |
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
