07-08-2016, 10:32 PM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| Replacement bearing options
Where is yalls go-to place for bearings for the scx-10? I just ordered a set of transmission bearings for my scx-10 and it came out to about $12 shipped from Fast Eddy bearings. Is there other good bearings out there because it just seems like that was alot for just those few bearings. Where do you guys order and how do u know the size?
07-09-2016, 05:56 AM | #2 |
I joined the Band! Join Date: Jul 2016 Location: United States
| Re: Replacement bearing options
Acer and Avid are my usual bearing suppliers, but $12 doesn't seem unreasonable for half a dozen bearings and shipping. you could also check e-Bay for bulk bearings in the sizes you need bearing sizes should be in the manual or I just measure them if I can't find the size Avid RC Bearings and Accessories RC Ball Bearings Acer Racing |
07-09-2016, 07:54 AM | #3 |
Ok, I checked Avid out and it looks like they go for $1 each, but then again shipping is another $5 or so. So really about the same as Fast Eddy. Yea I just looked up my manual and seen where it tells the bearing sizes. From either place it looks like I can buy kits or just the specific bearings individually. But I remember back when I had my nitro r/c buggy I would replace most bearings at once. Like for instance all the axle bearings or whatever else. Usually if one of those is bad then the others is too, or at least dang near it!
07-09-2016, 08:32 AM | #4 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I've had really good luck with Avid over the years, so thats what I stick with.
07-09-2016, 02:07 PM | #5 |
What best metal shield or rubber shield?
07-09-2016, 02:12 PM | #6 |
I prefer rubber sealed unless the bearing is inside a sealed axle or transmission housing
07-09-2016, 02:41 PM | #7 |
Quarry Creeper Join Date: Dec 2015 Location: United States
Been using Avid and Acer bearings for years without a problem, I generally buy rubber sealed.
07-09-2016, 07:15 PM | #8 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Locked up rc has entire vehicle or tranny only axle only type kits. I run their bearings in everything I own |
07-09-2016, 07:54 PM | #9 |
Do you guys generally replace all bearings at once? Or like the whole axle or what do yall do? Like for me I ordered the transmission kit, so that will take care of the whole transmission, but there is still bearings that are in the axles and Diffs and the front C-hubs...
07-09-2016, 11:06 PM | #10 |
I replace as I notice they start going bad but I've never torn a whole truck apart to do all new bearings.....or if I happen to be rebuilding say a front axle, I'll check bearings as necessary. Being that I spend 99% of the time in dry terrain, bearings last quite a while. |
07-09-2016, 11:14 PM | #11 | |
| Re: Replacement bearing options Quote:
I usually buy 20 or 30 of every size that my vehicles use , that way I have spares even during late night wrenching sessions. Buy more of wheel bearings because they usually go first. | |
07-10-2016, 05:45 AM | #12 |
Good word nate. And which bearings would you say last the longest? Maybe the diff bearings?
07-11-2016, 01:27 PM | #13 |
Do you guys do anything to your bearings or do you put them in like they are? I ordered some Cow RC Moo Slick and I heard somewhere that you can use them on bearings. So should I pop the rubber seal on my new bearings and give them a shot of Moo Slick or just use them like they come (new)?
07-11-2016, 01:41 PM | #14 |
I wanna be Dave Join Date: Dec 2006 Location: here
I replace old bearings with new bearings asis.. My problem isn't bearings it's the sloppy tolerance in my VP knuckles..... |
07-11-2016, 04:35 PM | #15 | |
07-11-2016, 06:10 PM | #16 |
Ok I was just checking. I know I have already removed my old bearings and you can very easily take a exacto knife and remove the seals and pop them back in place. Just for giggles I removed the seals on my "bad" bearing and sprayed some WD-40 Specialist Dry Lube all in there and the bearing is free rolling now. So my question is this, is this bearing still considered worn out? (I was having a decent amount of wobble/play in my spur gear, which is why im replacing bearings in the tranny). Or is once a bearing gets to where it has play, its trash? |
07-11-2016, 06:15 PM | #17 |
I'd toss it myself... did replace bearings fix your spur wobble?
07-11-2016, 06:27 PM | #18 | |
07-11-2016, 06:53 PM | #19 |
Still waiting on them to come in the mail. I just went ahead and tore everything down. But im sure the bearings will fix the slop, I can tell the old bearings were loose feeling. Also doing two rigs at the same time lol, my son blew his transmission in his yesterday (stock plastic gears) so I have him a new set of Hot Racing steel gears on the way and went ahead and got him a new set of bearings too while im at it. |
07-11-2016, 09:00 PM | #20 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
Kinda surprised nobody has mentioned BOCA brand bearings. Very high quality. I run BOCAS in my 300$ fishing reels and they do make a difference in that application so I'd assume they would be great for RC as well. I've robbed bearings out of my fishing reels to keep my rc going. |
Replacement bearing options - Similar Threads | ||||
Inner c bearing? Are they necessary? | cooterwrenchen | 1.9 Scale Rigs | 11 | 11-30-2015 06:51 PM |
Hub pin lost. Replacement ordered. Any DIY options in mean Time? | Learo2000GT | Axial Yeti XL | 3 | 08-16-2015 01:27 AM |
Replacement Chassis options? | little squirt | Losi Micro-Rock Crawler | 2 | 08-01-2015 05:46 PM |
Axial cvd starting to get some play...replacement options? | jtessmer88 | Axial Wraith | 6 | 08-05-2014 05:28 PM |
I don't understand why there are bearing grooves but no bearing Can go? | Mysterious | Axial XR10 | 12 | 01-14-2013 03:21 PM |
