09-14-2016, 12:46 PM | #1 |
| Hot Racing LCG SCX10 trans
Saw this on EBay, looks interesting. 11.4:1 reduction. Can run 48p pinion from 9t to 30t. Dig compatible and looks pretty compact for easier interior installs. Part number: SCP38X01
09-14-2016, 01:02 PM | #2 |
I wanna be Dave Join Date: Sep 2004
| Re: Hot Racing LCG SCX10 trans
is meant to be used as a transfer case?
09-14-2016, 01:08 PM | #3 |
No, that is the entire trans. Notice the motor mount plate?
09-14-2016, 01:12 PM | #4 |
I have one. From what I'm told it uses berg gears with one being larger to change the ratio. It's basically a Berg gear case (holes to attach axle tubes and all) with a different locker and 48 pitch first gear, the rest are .6 mod. The gears are lightened steel so it should be pretty tough. It'll also be tough to fit in a modern chassis. The whole transmission sits in front of the old trans location, the rear driveline isn't an issue but the front gets real short real quick.
09-14-2016, 01:15 PM | #5 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
That is interesting. Would give it a try.
09-14-2016, 01:16 PM | #6 |
Now I can see it's a modified MOA case. Thanks for the info WT.
09-14-2016, 02:58 PM | #7 |
Rock Crawler Join Date: May 2013 Location: Uniontown
Perhaps it would work better for motor forward setups than the stock AX Sent from my XT1585 using Tapatalk |
09-14-2016, 03:15 PM | #8 |
anyone have pics of it mounted up?
Hot Racing LCG SCX10 trans - Similar Threads | ||||
hot racing lcg tranny | toka100 | Axial SCX-10 | 3 | 11-21-2012 03:45 AM |
Hot Racing 3 piece SCX10 Trans mount/skid | rckjeep | Axial SCX-10 | 5 | 09-20-2011 10:53 PM |
How to: Hot Racing trans case | dockman | Losi Micro-Rock Crawler | 0 | 12-12-2010 09:22 AM |
