10-24-2016, 07:01 PM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Los Angeles
| SCX-10 throttle glitching with the BEC already installed??
I have been having problems with my SCX10. I already installed the BEC and set it to 7.4V for my Hitec 7950TH servo. I am not running a 2s battery but I think it effects the BEC. I can run it with no problems for 15 min, then it goes out. I only have steering and zero forward or reverse. Can somebody help?? Thanks. Sent from my iPad using Tapatalk |
10-24-2016, 07:06 PM | #2 |
| Re: SCX-10 throttle glitching with the BEC already installed??
I waterproofed it by removing the blue shrink wrap and put the whole thing inside plasti dip, I'm not sure if that effected the BEC's function? Sent from my iPad using Tapatalk |
10-25-2016, 07:14 AM | #3 |
I did the same thing to one of mine and had almost the same problem. also used the Plasti Dip on an ESC and fried it. Never figured out why, but never used it again to water proof.
10-25-2016, 07:34 AM | #4 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
Plastidip insulates heat really well. That may be part of the issue. I just plastidipped a sensored ESC, and I made sure to keep the heatsink exposed. I'm hoping this helps. One thing to look at though, did you make sure to remove the middle wire from your ESC to your receiver? If you are powering your receiver from 2 sources it can wreak havoc. |
SCX-10 throttle glitching with the BEC already installed?? - Similar Threads | ||||
Installed LED light bar now glitching | Grumpy's Toy | Electronics | 12 | 10-11-2016 07:41 PM |
Throttle Glitching | hutsontr | Electronics | 2 | 09-13-2011 03:29 PM |
Throttle Glitching | Drclarkin | Electronics | 10 | 06-03-2011 02:24 PM |
Just installed bec no throttle | JBennett | Newbie General | 2 | 06-09-2009 08:09 PM |
