05-14-2018, 07:16 PM | #1 |
Pebble Pounder Join Date: Nov 2017 Location: Noblesville
| Original scx10 axles - wider?
My roommate has an original scx10. He bought mudslinger 2.2 XL tires.. hes wanting to make a mud truck of some sort. He needs to widen the axles. How do we go about this? Wraith axles? Sent from my SM-G955U using Tapatalk |
05-14-2018, 08:12 PM | #2 |
| Re: Original scx10 axles - wider?
AR60 axles would work. They are wider and the links would need to be custom or if you can find some plates that are made to help mount them. I forget who the vendor is that makes them.
05-14-2018, 08:32 PM | #3 |
Im looking for the cheapest option.. is there any way to just extend the stock ones with longer dog bones and the end pieces? Sent from my SM-G955U using Tapatalk |
05-14-2018, 08:46 PM | #4 |
Looks for axles wideners on fleaBay. 15mm should be enough.
05-14-2018, 11:52 PM | #5 |
Quarry Creeper Join Date: May 2017 Location: Devon
And wider wheels perhaps. Sent from my Pixel using Tapatalk |
05-15-2018, 05:49 AM | #6 |
Boom racing makes XR width SCX10 axles. About 1.5" wider than stock so in between an SCX10 axle and AR60. Great axles, I have a set and they've held up well. PN (#BR233035BK front and #BR233035RBK rear)
05-15-2018, 05:55 AM | #7 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Boom Racing XR modify axles are the most budget axles I have ever know. Highly recommended https://www.asiatees.com/display?Axi...d=132352&pid=1 |
05-15-2018, 08:49 AM | #8 |
Wraith axles aren't great at handling power until you beef them up. Just be prepared to spend money if you're going to throw a lot of power at them. And that's if you keep the axles locked. If you try to run open diffs you'll destroy them even faster.
05-15-2018, 08:32 PM | #9 |
| Re: Original scx10 axles - wider? https://www.ebay.com/i/182713667833?...e153e3fff4b32a Are these any good? Sent from my SM-G955U using Tapatalk |
05-22-2018, 10:41 AM | #10 |
Rock Stacker Join Date: Jan 2017 Location: Kennesaw
You said you wanted the cheap route right? https://www.ebay.com/itm/17mm-Wheel-...0AAMXQeKNTO5wb These or something like them is the best and easiest. Bolt right up, nothing to take apart. Just put these between the wheel and the axle. |
05-30-2018, 11:09 AM | #11 |
Ended up going with the axle extensions as seen above... BUT for myself. Are scx10 II trail honcho ar44 axles wider? They look it.. Sent from my SM-G955U using Tapatalk |
Original scx10 axles - wider? - Similar Threads | ||||
Scx10 wider rear axles | Deefa72 | Axial SCX-10 | 3 | 04-03-2015 09:21 AM |
Wider Axles for SCX10 | rspicko | Axial SCX-10 | 10 | 08-22-2013 08:05 AM |
wider axles | tim the toolman | Formula Offroad | 2 | 03-11-2012 09:17 PM |
wider axles? how to | BIGIN | Newbie General | 12 | 03-27-2007 10:47 AM |
