11-15-2018, 10:35 PM | #1 |
Rock Stacker Join Date: Sep 2018 Location: Pierce
| Used scx10 questions.
So I bought a used scx10 for my son and when I got it I was told that is was a stretched wheel base. After having it and wanting to install a new body I can’t find one that would look right. The one on there is hacked up to make it somewhat fit. My question is when someone stretches the wheel base do they usually leave the front alone and just move the back wheels. It looks like he drilled some new holes and moved everything back about a 1/2 in to an inch. When I measure it it’s a little over 13 inches. I just want it back to stock so I can put a new body on it. I’d like to go to a 12.3 wheel base but I’m not sure if the front is set up for that or if they are all the same. He used the stock rear upper links all he did was drill holes and move them. However the bottom links look home made and the shock tower looks like it has been moved back as well. Hopefully I explained all of that right and makes since. Thanks for you time and help.
11-16-2018, 01:00 AM | #2 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: Used scx10 questions.
It would help alot if u could post pics. That would help us to help u. So we can see wat has been done. The easiest way to know uve got the 12.3 wb u want is to get new links. U can download the manual from google that has all the exploded veiws of everything, which will greatly help u out if something ever goes wrong. It shows part numbers for each part, and where they all go. Just look up axial scx10 exploded veiw n it will have a link for a pdf that will automatically start to download wen u click on it. Hope this helps. Sent from my SM-J327VPP using Tapatalk |
11-20-2018, 05:59 PM | #3 | |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Re: Used scx10 questions. Quote:
Please consult the following instructions for correct Axial stock setup: Short wheelbase http://www.axialracing.com/products/...9/instructions Medium wheelbase http://www.axialracing.com/products/...2/instructions Long wheelbase http://www.axialracing.com/products/ax30550 By the way, I hate the Axial rod ends. Sent from my SM-G930F using Tapatalk | |
11-20-2018, 06:42 PM | #4 |
I got HR (hot racing) links for the 12.3 wheelbase. They work great n look great. I think theyre bout $35 on ebay Sent from my SM-J327VPP using Tapatalk |
Used scx10 questions. - Similar Threads | ||||
Help, first scx10 many questions | too many hobbies | Axial SCX-10 | 5 | 08-08-2016 07:20 AM |
new scx10 questions | arp1500 | Axial SCX-10 | 4 | 04-07-2012 07:00 PM |
Just got a SCX10 and have a few questions | Tommy_Boy_1184 | Axial SCX-10 | 2 | 12-03-2010 07:46 PM |
Some SCX10 questions | 0124vctd | Newbie General | 8 | 04-13-2010 04:05 PM |
