Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: LC70 Questions
Old 11-18-2017, 04:12 AM   #1
Default LC70 Questions
I have wanted to get the LC70 body for a while now but does it fit on the SCX10 II chassis without modification.
I know the rear suspension will need altering but is that all?
Thanks
asimmd is offline   Reply With Quote
Old 11-18-2017, 05:01 AM   #2
Default Re: LC70 Questions
There is a mounting kit for the SCX10 ii & the LC70. It is flimsy & sets the body way up high. To get the body down, so the floor of the bed sits on the chassis rails (or close enough) you either:
A: Figure a way to lose the rear shock towers (the front works just fine & the flimsiness of the body mount is minimized) & mount the shocks to the bed.
B: Get a cantilever kit.
C: Cut a hole in the bed to clear the rear shocks & shock towers.
txbart is offline   Reply With Quote
Old 11-18-2017, 05:14 AM   #3
Thanks txbart
I have seen the cantilever kit and it looks good so that's the way I would go.
I have read somewhere that the LC70 Body wont fit the stock scx10 II chassis without modifying the motor.
Does anyone know anything about this please.
Thanks
Old 11-18-2017, 05:29 AM   #4
Depending on which version you have, kit or RTR the motor & transmission sits right in the middle of the cab/bed area to varying degrees. So you might have to do some cutting of the bed to accommodate the transmission. Give me a few hours & I can give you a more positive answer by comparing my Scx10 ii & LC70.
Old 11-18-2017, 07:28 AM   #5
Ok Thank you.
Old 11-18-2017, 08:04 AM   #6
Here are some pics,
My SCX10ii is a kit with the old style trans setup, like in the RTR. With the front wheel in the front wheel well & the body resting on the side plates, everything stays well within the cab. I don’t believe there would be much need to alter the body if you were to do alterations to the chassis.
Good luck!
Old 11-18-2017, 09:17 AM   #7
Thanks txbart the pictures are great.
I have read that there is a way to reverse the transmission
that means the chassis stays the same but I have searched
YouTube and I can't find anyone who has posted how to do it.
Thank you.
Old 11-18-2017, 10:19 AM   #8
Bowhouse makes a mount that lets you flip the motor/trans around... GCM racing has a video of one on a scx10, you can get the part from shapeways
crazhorse is offline   Reply With Quote
Old 11-18-2017, 05:20 PM   #9
Thanks crazy ores I'll check it out.
Old 11-20-2017, 09:18 AM   #10
This is what I did for my buddys build got the servo mount from circle city
Crisdog80 is offline   Reply With Quote
Old 11-20-2017, 09:20 AM   #11
Also made custom leaf spring mounts
Old 11-21-2017, 04:04 AM   #12
That's very good crisdog80.
I don't mind buying parts to fit to the truck but I'm not very good at making stuff from scratch.
LC70 Questions - Similar Threads
My LC70 Build Craggles123 Axial SCX10 II 24 10-23-2019 03:38 PM
My LC70 build Mello_Yello 1.5 Scale Rigs 11 01-09-2019 06:11 AM
Ifs lc70 wblteen 1.9 Scale Rigs 35 09-29-2017 07:07 PM
Mercedes G & LC70 ROB850R Scale Videos! 0 09-14-2017 02:17 PM
