09-22-2017, 04:32 AM | #1 |
RCC Addict Join Date: Oct 2014 Location: UK
| New SSD Brass Knuckles |
09-22-2017, 06:23 AM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
| Re: New SSD Brass Knuckles
A man just got to have a set of brass knuckles |
09-22-2017, 11:54 AM | #3 |
Quarry Creeper Join Date: Mar 2016 Location: juneau
Are they the same weight as your normal knuckles with brass weights bolted to them? Or would they be lighter? Sent from my SM-G892A using Tapatalk |
09-22-2017, 12:58 PM | #4 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
I'd say they are phat and heavy all by themselves.
09-22-2017, 01:26 PM | #5 |
great idea
09-22-2017, 02:48 PM | #6 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| Re: New SSD Brass Knuckles |
09-22-2017, 06:12 PM | #7 |
Newbie Join Date: Feb 2015 Location: Winchester, VA
These will be on the zuki v2 build I'm doing next! Availability?
09-25-2017, 04:35 AM | #8 | ||
| Re: New SSD Brass Knuckles Quote:
These new brass knuckles are 70g each. | ||
09-25-2017, 11:02 AM | #9 |
Newbie Join Date: Sep 2017 Location: Los Angeles
do these knuckles limit the steering in any way? I am looking to get new knuckles and was set on the aluminum pro version with weights but in light of this new product I am curious as to the pros and cons versus the 2. first difference I see is the price so with these new knuckles I can get more weight for cheaper then your other setup is this correct? is there any other differences besides the obvious? thanks in advance. p.s. I already have the pro rear lockouts on order, are u guys releasing new versions of those as well? |
09-25-2017, 11:33 AM | #10 | |
No, there wont be any new rear lockouts from us. | |
09-25-2017, 02:39 PM | #11 |
09-29-2017, 04:38 PM | #12 |
Rock Stacker Join Date: Mar 2016 Location: St. Louis
09-30-2017, 05:01 AM | #13 |
Quarry Creeper Join Date: Dec 2016 Location: Womelsdorf
I ordered a set last evening from RPP along with a set of the SSD black rear hub/wheel nut. . 70g a piece compared to 50?or 55g from the SSD knuckle rotor/weight which was plenty heavy in my book. These should keep any front end comfortably planted. I also love the almost black look to these. No paint required to tone down the brass color.
10-02-2017, 07:34 PM | #14 |
I received mine today from RPP. These things are huge and heavy! I won’t be installing them until this weekend, so no review until then.... Sent from my iPad using Tapatalk Pro |
10-03-2017, 09:33 AM | #15 |
Mine will be here today..... I will be swapping out my SSD Aluminum Knuckles and Brass Weights for THESE! |
12-22-2017, 10:12 AM | #16 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
What are people doing on the rear in conjunction with these Brass Knuckles? I have the SSD Knuckles, C-hubs and lockouts with Brass weights on my other II. For my current project I'm going to try another SSD route. I picked up some SSD Pro44 axles/HD diff cover with SSD C-hubs. I'm going to do brass knuckles on the front and am wondering if people are also adding weight to the rear or not and by what means? I'm not sure if you can add SSD's brass weights to the rear Pro44 axle since it doesn't have the same mounting holes as their Lockouts. edit to add: Does anyone have these in stock right now? Checked RPP, Amain, Hobbytown, Amazon and several others already... Last edited by powder4breakfast; 12-22-2017 at 10:25 AM. |
12-22-2017, 05:51 PM | #17 | |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Weight inside the rear wheels Ssd rear lockouts with the weights Make your own weight system for the rear Pretty much, you could get creative with it | |
12-22-2017, 06:03 PM | #18 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
I put some on my truggy build. Had some minor sanding to get one inside bearing to fit. Also the axial 8hole wheels just rubbed the knuckles so I slapped some beef patties on to bump them out a touch. Now everything is free and clear. Loves these knuckles. Sent from my iPhone using Tapatalk |
12-23-2017, 05:50 PM | #19 |
RCC Addict Join Date: Feb 2008 Location: your back yard
I added them to my truck today without issue. Matched with ssd axles I got plunty of weight down low. Sent from my SM-G930V using Tapatalk |
12-23-2017, 06:25 PM | #20 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
Kind of bummed that they rub on stock Axial beadlocks. Have to run 8mm hexes to get them to clear. The fit and finish is top notch though.
New SSD Brass Knuckles - Similar Threads | ||||
New SSD Brass Portal Weights | SSD | Traxxas TRX-4 | 21 | 12-26-2020 02:27 PM |
New SSD Brass Knuckles | SSD | Vaterra Ascender | 29 | 11-29-2018 08:47 AM |
Hot Racing Brass Knuckles and SSD Brass Weights compatibility | saddlesore | Axial SCX10 II | 5 | 07-15-2017 04:27 PM |
