08-16-2018, 11:31 AM | #201 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Re: New SSD Pro44 Axles
I guess xr width would be fine but I personally think narrowed axles would sell better. Either way I think they will be a niche product for custom builds. Sent from my iPad using Tapatalk |
08-16-2018, 12:42 PM | #202 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: New SSD Pro44 Axles |
08-18-2018, 01:06 PM | #203 |
Quarry Creeper Join Date: Oct 2010 Location: Rhode Island
Wait.........What??? SSD Portals???? For the AR44??? What did i miss???
08-19-2018, 04:59 PM | #204 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
SSD : I was looking for XR width for C3. You're diamonds/AR44 gear is just so good and sized well that I think it would be great. Initially I came about this issue as I was building a C2 rig with your axles then mid way decided to change it to C3 but obviously have a lot of gear. I need the extra width to allow the full steering with large tyre combo I want to run - rather than adding extenders that mess the arc up. I guess it could always be used on another project but seemed a shame. That said, if the portals are imminent and reasonably priced I could possibly work that on a Unimog project. As to hubs etc, I initially assumed it would be XR/wraith type stuff with XR shafts. With that said, your weighted hubs etc are rather good and would possibly help in your line up... Then its working shafts out. Last edited by stimpy; 08-19-2018 at 05:07 PM. |
01-20-2019, 09:27 AM | #205 | |
Newbie Join Date: Jan 2019 Location: Hong Kong
I have bought the SSD portal knuckles and rear portal axle for my SCX10 II. I have taken it out for trailing 3 times, the 1st time, everything was fine, the second time, one plastic axle tube was broken and it caused the shock shaft and lower link to break too. The 3rd time, both two plastic axle tubes were broken and I was exhausted in this problem. I am strongly request SSD to provide metal axle tube for the rear portal axle. I really don’t want to break the plastic axle per each run. I took my truck for hiking, and the axle was broken in the mid way, I needed to take the truck walking for more than one hour to the destination, it is not fun ..... PHP Code: Quote:
01-20-2019, 09:35 AM | #206 | |
| Re: New SSD Pro44 Axles Quote:
I have bought the SSD portal knuckles and rear portal axle for my SCX10 II. I have taken it out for trailing 3 times, the 1st time, everything was fine, the second time, one plastic axle tube was broken and it caused the shock shaft and lower link to break too. The 3rd time, both two plastic axle tubes were broken and I was exhausted in this problem. I am strongly request SSD to provide metal axle tube for the rear portal axle. I really don’t want to break the plastic axle per each run. I took my truck for hiking, and the axle was broken in the mid way, I needed to take the truck walking for more than one hour to the destination, it is not fun ..... | |
01-20-2019, 11:37 AM | #207 | |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Sent from my SM-J327VPP using Tapatalk | |
01-25-2019, 12:38 PM | #208 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
So far so good. I am most definitely putting the axles to the test. One suggestion is to include the hardware for the link mounts. Especially now that the one piece axles are more prevalent and dont come with that off-size hardware. Lucky I had some that worked. Great quality and nice low weight. Sent from my SM-N950U using Tapatalk |
01-25-2019, 04:14 PM | #209 | |
If you buy the center section and tubes, link mounts and Chubs are not part of it. The first gen axles came with red plastic link mounts. Thats too many variations to plan for. What link mounts dont come with screws? My VP ones did. | |
01-25-2019, 04:18 PM | #210 |
I bought the RBK. So I didnt have link mounts. Got some stock ones from a buddy. Not complaining. Like the axle a lot Sent from my SM-N950U using Tapatalk |
03-10-2019, 01:40 PM | #211 |
Rock Crawler Join Date: Dec 2010 Location: tracy
Would love to see a scale option for these awesome pro44 axles. Like offset pumpkin. Just change the lengths of the axle tubes. Sell the tubes with a pair of modified axle shafts also. And maybe just a solid tube without provision for the link mounts, so you could use leaf springs... PLEASE! Sent from my Moto Z (2) using Tapatalk |
New SSD Pro44 Axles - Similar Threads | ||||
Ssd pro44 axle | redemon | Chit Chat | 36 | 10-07-2017 06:15 AM |
SSD Pro44? | 4RunnerKid | Axial SCX10 II | 5 | 10-06-2017 03:28 AM |
SSD Axles | GravelDuster | Axial SCX-10 | 2 | 12-19-2015 10:10 AM |
