10-29-2017, 11:02 AM | #1 |
Newbie Join Date: Dec 2012 Location: Honolulu
| Scx10ii axle grinding
So I put my kit together but I noticed the kit does not Free roll and I have a grinding in both front and rear axles I went through them and could see no defects If I pull the pinoin out it is fine I’m just wondering where would I place a shin to keep It pulled outward |
10-29-2017, 01:22 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
| Re: Scx10ii axle grinding
So i assume you dont have the 2 drive axles connected, seem like they have to be that to run smooth with this setup. I really dont like the free floating input axle in these axles, seem to cause so much grief and panic to many building this truck. |
10-29-2017, 01:48 PM | #3 |
I’ve changed the drive shafts to the hot racing Ones and I tried a different ring and pinoin And different axles housing I’m missing somthing I just don’t know what Only thing I didn’t do was shim it But where do I put the shim if it goes between the pinoin And pinoin bearing it binds even more |
10-29-2017, 11:00 PM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Put the shim or an oring on the shaft at the outside before you fit the driveshaft, will keep the gear pulled out against the inner bearing
10-30-2017, 12:02 AM | #5 |
I Will give that a go thank you
10-30-2017, 02:09 AM | #6 |
Rock Stacker Join Date: Oct 2014 Location: New zealand
If you pull the driveshaft out when you turn the gears does the grinding go away? Mst cfx Axial wraith Axial yeti 8x venom creeper |
10-30-2017, 07:44 PM | #7 |
Issue solved I added shims where altd said and it’s all G now thank you for all your love and support lol
11-01-2017, 03:20 AM | #8 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
Just so you know the front will not be an issue without the the shims as it will push the pinion out at it drives forward
11-01-2017, 03:37 AM | #9 | |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: Scx10ii axle grinding Quote:
It's the same setup/design as the Bully 2 rear axle. | |
Scx10ii axle grinding - Similar Threads | ||||
Vp currie axle diff grinding while setting up | 12vctd | Axial Wraith | 31 | 08-29-2013 10:30 AM |
CR-01 Differential/axle grinding? Please advise | theplaz13 | Tamiya CR-01 | 18 | 05-10-2011 08:47 PM |
grinding axle housings | Redfinger | EnRoute Berg | 5 | 01-15-2010 09:16 PM |
Berg Axle Grinding? | Raney120 | EnRoute Berg | 15 | 12-10-2009 02:48 PM |
Axle Grinding!!!!! | swamped2a | General Crawlers | 2 | 11-03-2005 08:02 AM |
