08-23-2013, 08:34 PM | #1 |
Newbie Join Date: Aug 2013 Location: South texas
| Vp currie axle diff grinding while setting up
I've got a set of VP currie axles that I'm trying to set up with axial hd gears. When I barely tighten the bearing caps I can't spin the gears by hand. I'm using hpi bushings B072 for pinion Hot Racing locker and axial HD gears for front diff. I set up my rear with the HD under drive gears and they spin fine. I've tried a assortment of brands of bearings under the cap all 10x15x4. The cap screw have to be very loose to allow the gears to turn by hand anyone have this issue before? What did you do to fix it.
08-23-2013, 09:12 PM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: Queen Creek, AZ
| Re: Vp currie axle diff grinding while setting up
Call VP.
08-23-2013, 09:33 PM | #3 |
RCC Addict Join Date: Sep 2009 Location: sacramento
make sure caps are on the right way
08-23-2013, 09:44 PM | #4 |
They are installed with larger curved side over bearing. I am pretty sure this is the right way
08-23-2013, 10:04 PM | #5 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
I had the same problem! Spent hours swapping out parts to get these axles to fit properly ! Good luck!!!!!!!!!!
08-23-2013, 10:08 PM | #6 |
What locker were you using I'm gunna crawl? What changed things for your axles to work?
08-23-2013, 10:28 PM | #7 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
I installed a currie wraith axle and had the same problem. Just tighten it snug and use some blue Loctite. |
08-23-2013, 11:17 PM | #8 |
If I barely snug them they lock up. I will try again tomorrow .. Thanks for the input guys
08-23-2013, 11:36 PM | #9 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
What happens when you tighten the bearing caps without the pinion installed?
08-24-2013, 03:56 AM | #10 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
sounds like VP finally failed on something...
08-24-2013, 09:40 AM | #11 |
Rock Crawler Join Date: Oct 2011 Location: Lake Worth
You have to bring the interior alittle VP already knows of this issue. The inner bearing rings hits the side of the housing just barley and causes it to bind. I used a dremal to shave a tiny bit off the housing to clearance the bearing. They spin freely with the diff clamps all the way tightened down. If you search there is another guy on here that even shows a diagram of what has to be done.
08-24-2013, 10:12 AM | #12 |
Pebble Pounder Join Date: Sep 2009 Location: Rockport, TX
| Re: Vp currie axle diff grinding while setting up The other issue may be your short axle is a tad long. I had the same problem and shipped the whole thing to VP. They called and said Axial made a change in the short axles length sometime last year. He threw a new short shaft and it worked fine. You might post this in the VP vendor section as well. |
08-24-2013, 10:35 AM | #13 |
Easiest fix is to sand 0.05mm off of the inner bushing. It's very simple.
08-24-2013, 10:43 AM | #14 |
Thanks for the replies. Since I am using bushings I try to sand them down thou I dunno if I can get exactly .05mm I will sure try. Thanks for all the helpful info. I did try to search but I must have not used proper terms to get what I was looking for.
08-24-2013, 11:57 AM | #15 |
| Re: Vp currie axle diff grinding while setting up You by no means have to be exact. Just rub the bushing on some sand paper and test fit, repeat until the desired mesh is accomplished |
08-24-2013, 02:19 PM | #16 |
Worked like a charm thank you for the help
08-25-2013, 08:22 PM | #17 |
Moderator Join Date: Jan 2004 Location: chicago
08-25-2013, 10:13 PM | #18 |
I still plan to buy them.
08-26-2013, 12:13 PM | #19 |
| Re: Vp currie axle diff grinding while setting up |
08-26-2013, 05:53 PM | #20 |
Vp currie axle diff grinding while setting up - Similar Threads | ||||
Tamiya cc01 rear diff grinding | Joshperin | General Crawlers | 3 | 06-05-2013 09:48 PM |
Currie axle... | Tbuck | Vaterra Twin Hammers | 3 | 03-13-2013 05:18 AM |
grinding axle housings | Redfinger | EnRoute Berg | 5 | 01-15-2010 09:16 PM |
Axle Grinding!!!!! | swamped2a | General Crawlers | 2 | 11-03-2005 08:02 AM |
Mean grinding coming from the rear diff.... | Vu14TJ | XTM Crawler | 6 | 09-01-2004 03:52 AM |
