![]() | #41 |
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Nice work Gavin ![]() To give some perspective to the other parents that may be reading this, at the time when the roof was cut off, Gavin was 15 years old. ![]() And thank you to Shelby (4xFord) for the infusion of crawler parts last year that provided Gavin with this interior and me with some needed inspiration. |
![]() | #42 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
Awesome build. I’m going to be tearing apart one of my ascenders so my daughter 4.5, and I can build it together and make it her own. Very nice design and metal work. How much does this rig weigh? Are you kit welding the joints? Some look like kit but others look like tig or brazing. Keep up the good work! Ben |
![]() | #43 | |
Quarry Creeper Join Date: Aug 2017 Location: Tyler
| ![]() Quote:
Thanks Ben! All the joints are Tig welded and the weight as it sits today with more metal weighs 7.72 pounds RTR so i would guess that at this stage of the build it weighs around 7 pounds. | |
![]() | #44 |
| ![]() Pics of the Chuggy together! I added lights,boatsides panels, and my Mom made me the fabric top. ![]() ![]() ![]() ![]() ![]() |
![]() | #45 |
| ![]() Interior shots. ![]() ![]() ![]() I welded a new rear upper link mount to the frame. New titanium rear uppers and lowers. ![]() ![]() |
![]() | #46 |
| ![]() ![]() More tubework and nuts for a new boatside panel. ![]() ![]() After one year of hard driving the first axle shaft broke. These axles have great strength over the old axial SCX10 axles. ![]() ![]() |
![]() | #47 |
| ![]() These Rock Beast have been through alot. ![]() These tires and foams are 1 year old. All the tires had worn down the tread and started ripping holes ![]() ![]() C.I Foams Front Foams-Lil Nova 4.50 Comp Cut/Soft- CRW-2024 Rear Foams-Lil Nova 4.50 Comp Cut/Medium- CRW-2025 ![]() ![]() ![]() |
![]() | #48 |
| ![]() New Aluminum 1/16 boatside rocker panels and new tires/foams mounted. I changed the rear lower links to a 2 bend instead of the one bend titanium link. ![]() ![]() ![]() |
![]() | #49 |
| ![]() Breakage So I broke the three locker bolts right off. I replaced the stock locker with a Vanquish Products locker and then stripped the three bolts off AGAIN. So I then new that the Three bolt would never hold so I Tig Welded the ring gear to the locker.![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | #50 |
| ![]() Trail Pictures ![]() ![]() ![]() ![]() ![]() |
![]() | #51 |
| ![]() More Trail Pics ![]() ![]() ![]() |
![]() | #52 |
| ![]() New Shoes Try On. Pitbull Rock Beasts (original XOR) ![]() ![]() ![]() ![]() |
![]() | #53 |
| ![]() Video of the chuggy! Pictures from the video ![]() ![]() ![]() ![]() |
![]() | #54 |
![]() | #55 |
Quarry Creeper Join Date: Sep 2013 Location: Hicktown
wow this is an awesome build. I had not even considered the Pit bull tires but see how they wear and look, I really like that and will have to pick up a set. Are you running the 1.9s? How heavy is your truck? Im still trying to figure out what foams will work best for my SCX10.2 |
![]() | #56 | |
| ![]() Quote:
Yes I am running the pitbull 1.9 Rock Beast Link to- PitBull Tires -I am running. The Chuggy Weighs 7.72 pounds and I run these foams. CrawlerInnovations Lil Nova 4.50''Comp cut / Soft Foam Pair Front; CWR-2024 Lil Nova 4.50" Comp Cut / Medium Foam Pair Rear; CWR-2025 | |
![]() | #57 |
| ![]() So I wasn't happy with the rear upper links. I tried the links in the stock skid plate and didn't like it. I then tried Tig Welding higher chassis mounts to the frame and the axle still swayed side to side. So I Tig welded new chassis tabs for new rear upper link mounts with more triangulation and shorter links. The axle does not sway with the new chassis mounts and the Chuggy drives alot better. New rear upper Links Vanquish Products 3/16x100mm Titanium ![]() These pictures don't show the rear upper links that well but I have better pics to post in time and New Stickers On The Chuggy. ![]() ![]() ![]() ![]() ![]() |
![]() | #58 |
| ![]() More ![]() ![]() |
![]() | #59 |
Nice. Any reason why you are not running the xl version? Just curious. Since your rig is now open wheel and all...
![]() | #60 |
| ![]() I know the XOR tires are not the most scale, but these 1.9 versions on the Chuggy look "beast". ![]() Last edited by Nova's Ark; 11-24-2018 at 08:19 AM. Reason: spell check |
Tags |
#activatedoutlaw, #ayalametalworks, #crawlerinnovations |
WJ Grand Cherokee Built with SCX10 II featured with front placed transmission | clarketian | 1.9 Scale Rigs | 10 | 10-02-2019 12:19 AM |
the old blue chuggy | 4x4boy | 2.2 Scale Rigs | 13 | 12-08-2009 09:36 PM |
