Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Possible to build a 9.5-10" wheelbase SCX10 II out of the Raw Builders Kit?
Old 03-29-2019, 12:47 AM   #1
Default Possible to build a 9.5-10" wheelbase SCX10 II out of the Raw Builders Kit?
I'm planning a Wrangler YJ build originally to use the RC4WD Trail Finder 2 SWB, but the Axial RBK is a better deal for me. Only problem is that its only configurable down to 11.4" at its shortest. With custom links, is it possible to make it even shorter?
wwaveform is offline   Reply With Quote
Old 03-29-2019, 02:45 AM   #2
Default Re: Possible to build a 9.5-10" wheelbase SCX10 II out of the Raw Builders Kit?
Funny you should ask, this is from the SCX10 thread:
https://www.boomracingrc.com/axial/s...t-black-119405
durok is offline   Reply With Quote
Old 03-29-2019, 05:05 AM   #3
To answer your question, it is possible to make it that short with custom links. It's just when shortening it that much, the chassis may get in the way of the body sitting low.
Sent from my Moto G (4) using Tapatalk
rcdriftmasterj is offline   Reply With Quote
Old 03-29-2019, 08:58 AM   #4
10.5" is easy, links only.
Shorter than that will require frame mods, and shorter shocks. You can section the frame in front of the skid and remove about an inch. The rear wont be a problem, just lop some off the rear and drill new holes. With shorter links the drive shaft angles will be steeper limitiing your wheel travel.
lonleycreeper is offline   Reply With Quote
Old 03-29-2019, 02:11 PM   #5
That's EXACTLY what I'm looking for! Thanks!
Old 03-29-2019, 05:01 PM   #6
I built a 10 1/2" chassis using SCX10.2 parts not the kit (I just didnt want that tranny) and to get that short I had to adjust the front and rear, remake the battery/servo mount shock hoops panhard location, I scooted the skid forward as it would sit pretty far back if you leave it alone, the spur cover needed to be cut up to get clearance to the links which were already bent for clearance.
Build thread: Caught the Bug (Scorcher Build)
Theres quite a bit of fine tuning to it so If Boomracing has that as a kit maybe its worth it. I still cant stand their low grade aluminum so I cant say I'd use them personally.
HumboldtEF is offline   Reply With Quote
Tags
wheelbase
Possible to build a 9.5-10" wheelbase SCX10 II out of the Raw Builders Kit? - Similar Threads
raw builders kit transmission question redbull8983 Axial SCX10 II 18 11-10-2019 07:28 AM
Cherokee kit or Raw Builders Kit? Can’t decide! twentyniner Axial SCX10 II 12 12-02-2018 09:14 AM
Raw Builders Kit Missing Diff Bearing smog Axial SCX10 II 17 11-29-2018 08:01 AM
SCX10 II raw builders kit-questions Spence Axial SCX10 II 2 11-11-2018 07:34 AM
